trans swap from a 99 2.2 l to a 99 2.4 motor? - Transmission Forum
Monday, February 25, 2013 8:01 PM
will this work? I have been told the only difference is the gearing. (manuel trans by the way) trans I am trying to put in my 99 2.4 is out of a 22 motor car.
Re: trans swap from a 99 2.2 l to a 99 2.4 motor?
Tuesday, February 26, 2013 6:14 AM
You need the 2.4L transmission. Since they are the same year motor the gearing is the same, but the transmission bellhousing is different.
If you can afford it though, get the 00+ 2.4L Getrag tranny. The -99 Isuzu is a pile. There are threads that show you how to do the swaphere.
Tuesday, February 26, 2013 6:45 AM
2.2 AND 2.4 have different bell housings. aka the bolt pattern that bolts the trans to the engine.
Friday, March 01, 2013 8:54 AM
Bellhousings are different, and gearing is different. The final drive ratio is the biggest difference internally.
Friday, March 01, 2013 11:21 PM
Sell you my 02 2.4 getrag tranny with 130k on it, flywheel with clutch kit only 10k on that and shifter cables for it. Pulling my motor and trans out and finally going ECO power so no use for it
FuzzMASTA9
Sunday, March 10, 2013 10:51 AM
how much you want for it and where are you located
