Engine Swap - Transmission Forum
Engine Swap
Wednesday, April 17, 2013 5:54 PM
Hi guys, I have a 1997 sunfire 2.2l manual transmission, that I would like to swap over a 1999 2.2l automatic transmission motor. From what I understand this swap should work as the transmissions from 1997-1999 did not change in the 2.2L, I will however have to swap the flywheel and clutch over to the the motor. So here is my question I have the full wiring harness that goes with the 1999 motor that will be going in and all the components of that wiring system, however I would think that the wiring will be a bit off from its new use as it came out of an automatic car and is going to be used in a manual transmission car. Is there a way to make this wiring work? I would think that the only major issue would be the brake switch and clutch pedal wiring? All the help you can provide will be much appreciated.
