ecotec auto to manual trans swap - Transmission Forum
Monday, February 09, 2015 6:40 AM
Ok heres my questions on a lot of these i see that one says you need a manual dash cluster and harness other newer ones that dont and no where do i see how are reverse lights would work when swapped over ... Also a full list of parts that i will need and also my plans are to have this supercharged as well so clutch kits and flywheel choices if anyone has any thoughts would also be a big help as well i plan on having all the mounts being polyurethane as i have done that already with the lower dogbone and the upper motor mount or does that need to be changed as well...
Re: ecotec auto to manual trans swap
Friday, February 20, 2015 10:12 PM
I have an 04 lss auto converted to manual, has all poly mounts including trans and engine mounts, manual gauge cluster and console. i didnt do th eswap just bought the car last weekend like this already, seems the way they welded the trans mount makes my engine sit way forward though, idk if this is normal for these swaps.
