backspacing? - Wheel and Tire Forum
backspacing?
Monday, September 13, 2010 12:18 PM
Ok so I'm in the market of buying new rims. Would a rim with 4in back spacing look/fit right on my cavy?
Re: backspacing?
Monday, September 13, 2010 4:34 PM
That's not nearly enough information for anyone to give you an answer.
Re: backspacing?
Monday, September 13, 2010 4:40 PM
Okay they are cragar soft 8's 16x7 with a back spacing of 4inches. On a 98 sedan
Re: backspacing?
Monday, September 13, 2010 4:52 PM
That's better. In order for the backspacing to mean anything, you need to know the rim size, particularly the width.
That is a low backspacing for our cars, because a 7" rim is actually close to 8" in overall width. This means that with 4" backspacing it is pretty much a zero offset rim. Our cars need a positive offset. On a 7" rim, you want somewhere between 35 and 45mm, which would equate to 5-5.5" backspacing.
Re: backspacing?
Monday, September 13, 2010 4:56 PM
With out any offset will it effect performance? Or handling?
Re: backspacing?
Monday, September 13, 2010 5:03 PM
The wheels will stick out from under your fender, which in most states is not legal, but also you run a real good chance of rubbing tires in your wheel openings when you turn.
Re: backspacing?
Monday, September 13, 2010 5:07 PM
Dang I guess I'm stickin with the stock steelies. Thanks man
Re: backspacing?
Monday, September 13, 2010 8:08 PM
jonboy wrote:Okay they are cragar soft 8's 16x7 with a back spacing of 4inches. On a 98 sedan
cragers came in 5x100?
Re: backspacing?
Tuesday, September 14, 2010 9:00 PM
Thats kinda what I was wondering.
