2011 Build - Wheel and Tire Forum
2011 Build
Wednesday, April 06, 2011 5:33 PM
Need to know if these 18x8 ASA AR3's will fit with 1.2" drop and 225/40/18 tires? They have a 35mm offset..
Link to pic:http://www.tirerack.com/images/wheels/asa/swap/asa_ar3_mba_ci3_l.jpg
Or should I run these Enkei EKM3 18x7.5 with 225/40/18, 45mm offset...
Bright Silver: http://www.tirerack.com/images/wheels/enkei_performance/swap/enkei_ekm3_bs_ci3_l.jpg
Gunmetal: http://www.tirerack.com/images/wheels/enkei_performance/swap/enkei_ekm3_gm_ci3_l.jpg
Opinions?
Re: 2011 Build
Wednesday, April 06, 2011 6:07 PM
yes, so did you find another set like the wheels in my sig?
Re: 2011 Build
Wednesday, April 06, 2011 7:14 PM
Nope... Only had time to look at google images so far....
So which ones would you go with? The Enkei or ASA wheels?
Re: 2011 Build
Wednesday, April 06, 2011 7:17 PM
asa
Re: 2011 Build
Thursday, April 07, 2011 9:19 AM
I like the Enkei wheels personally, the offset is a lil high but w/e
Re: 2011 Build
Sunday, May 22, 2011 4:02 PM
What offset should I run on a 18x8 wheel? 35mm, 45mm??? Please help.....
Re: 2011 Build
Sunday, May 22, 2011 11:15 PM
run 30-35.. or if you want to get crazy run a 25mm. my fronts are at a 28mm and rears are a 25mm after 10mm spacers.
