215/45/17 or 225/45/17 opinions - Wheel and Tire Forum
Friday, May 30, 2014 5:04 AM
Didn't want to jack the other thread on questions for 17's. I've always run 215's but now seeing a bunch of posts on 225's. A little ruff on 215's but never minded it. And I know 225's pretty dam close overall. Opinions? 2004 Cavalier stock suspension.
Re: 215/45/17 or 225/45/17 opinions
Friday, May 30, 2014 8:50 AM
225/45/17 is the proper size for a 17" wheel.
Tuesday, August 05, 2014 3:10 AM
YOU CAN EVEN PUT 235 IN BACK NO PROBLEM WITH A 17X7 INCH WHEEL AND 225 UP FRONT ,THATS THE SETUP IM ROLLING AND I DONT CARE ABOUT TIRE ROTATION I CAN GET THEM ON THE CHEAP
BLACKMANTIS
Tuesday, September 16, 2014 7:52 AM
WELL IF YOU CAN'T GET THEM ON TEH CHEAP,
Then 225/45/17 will work perfect all around. 215 looks like one of those cheap tire packages people buy just to save $30. Go with 225, then lower it a bit. You won't be sorry.
Friday, November 21, 2014 7:27 AM
Absolutely go with the 225 on a stock vehicle. It's a small difference, but the 215 on a stock height is going to look weird. I've seen it on enough stock Cavaliers, and they always look undersized. That magic balance between side wall height and the gap between the top of your tire and the wheel opening really makes a difference.
The 225 will absolutely ride better too, given the same brand and model of tire.
Tuesday, June 30, 2015 8:13 AM
225/45/17 ALL DAY - Can't believe I went with 215/40/17 for years. Much better difference in handling not to mention the overall look of the car - meatier tires always looks better IMO.
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
