16x8 et15? - Wheel and Tire Forum
16x8 et15?
Thursday, January 01, 2015 12:21 PM
Would these fit with a 205/55r16? I'm planning bc coilover extreme drop, rolled/pulled fenders on a 2004 ls sport sedan. I've seen plenty of you guys running 8.5/9" wide wheels but usually 17"/18" wheels.
R.I.P darknstrangecavie
Re: 16x8 et15?
Friday, January 02, 2015 2:52 PM
I'm running 17x8 with 225/45r17 tires my et is 45mm, in the front It basically flush with the fender I rub allot but also don't have my fenders rolled yet. 15mm offset seems like you'd have problems unless you run a stretched tire. Even then depending on how low your going you might still have problems. Check out this site http://www.rimsntires.com/specspro.jsp fill in the stock parameters then put in the setup you wanna run. It will tell you how close it will be to the fender ect.
Re: 16x8 et15?
Friday, January 02, 2015 3:31 PM
+15 will be mexi flush on an 8" wide wheel.
Re: 16x8 et15?
Friday, January 02, 2015 3:54 PM
Thank you. I thought it seemed a bit high.
