wiring reverse indiglos - Interior Forum
Sunday, February 20, 2005 8:40 PM
i just ordered my reverse indiglos and i know how to wire them up cause they are plug and play and i know u ground the negative and the positive is ur power source but my question is on the 03-04s there is a right headlight fuse and a left headlight fuse but is the any other headlight fuse or relay that controls both or what fuse do i need to tap into so that they come on when u turn the headlights on..thanks for any help
Re: wiring reverse indiglos
Sunday, February 20, 2005 9:47 PM
anybody?
Sunday, February 20, 2005 11:07 PM
im having the same problem, i know for a fact......do not tap into the headlight fuses, they are constant power.......ive heard that the harness going into the cluster has a grey wire next to a black wire, and if you tap the red wire on the overlay into the grey wire on the harness the lights will act like stock, IE. only on when the lights are on......on mine for now its tapped into the wipers so its on whenever the car is, but im gonna change that tommorrow
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Monday, February 21, 2005 2:57 AM
ok, there is a brown wire coming from the left side of the column, that leads to the handle that you turn on the lights with. tap the power to that brown wire, and then ground the other wire. i used the cigarette lighter to ground it. the brown wire is the one that sends the lead to the lights when you turn em on.
<A HREF="http://www.cardomain.com/id/eazy716"><IMG SRC="http://registry.gmenthusiast.com/images/eazy716/personal_pic.gif" BORDER="0"></A>
Monday, February 21, 2005 8:10 PM
ahh....ok, sounds easy enough
Hail Satan
