2011 new year new mods - Page 6 - Photos & Media Forum
Looking great man!
Love it
Question, do you know if you get good oil pressure out of that port on the exhaust cam for your turbo(im assuming thats your turbo feed)?
gtpsunfire wrote:Everything looks awsome man.
I see a spare cover for the cam tower, please sell it to me.
Thanks, the cover is already sold
Somebody want a cool engine bay too
WHITECAVY wrote:Love it
My oil pressure sensor was on this port last year , I have 90 psi when the engine cold and between 20-50 psi when hot at idle
I'm running mobil1 15w-40 oil
How much to make a new cover like that for me?
Ok, because I was using that same port for my turbo feed but it didnt seem to be oil coming out of when I took the fitting off, it was barely wet.
gtpsunfire wrote:How much to make a new cover like that for me?
30 shipped
polished or black polished
You want polished I guest ?
Polished, if you do online banking, let me know your email address and i will send u cash now.
I really want you to make me that little adapter coolant line you made for the (forgot what its called.....that should'nt be made of plastic) coolant neck thats on the side of the head.
I hate that dam line going over the exhaust.....thats so stupid.
GMR has got nothing on this
DOHC_tuner wrote:I really want you to make me that little adapter coolant line you made for the (forgot what its called.....that should'nt be made of plastic) coolant neck thats on the side of the head.
oh but then the coolant doesnt get nice and warm before going into the overflow tank and the engine could run a little cooler which could increase performance, you dont want that
mcmoney wrote:It's a 2.2 ps pump in place of the ac compressor
aluminum ps and alternator pulley is already on my drawing table
is that a direct swap and bolt on? (other than rerouting ps pump lines and getting longer ones)
same belt and ps performance?
Me as well.
What about using the Ho water neck and taping it and running a braided line or something?
^^Right,
Just cut the damn hard line close to the side of the head, slap on a braided line with a clamp and be done with it. That is how Ive been running mine for 5 years now.
Wow all I can say is dedication well done man
WHITECAVY wrote:^^Right,
More info on this please and pics if possible
DOHC_tuner wrote:WHITECAVY wrote:^^Right,
What more info do you need? I explained it in black and white right there lol.
Ill get you a pic in a lil bit.
2012 numbers - 4SPD
AUTOMATIC!!
alias wrote:mcmoney wrote:It's a 2.2 ps pump in place of the ac compressor
Yes same belt
I did the pulley smaller to compensate for the difference in size between the 2.4 and the 2.2 crank pulley
to keep the same flow of the ps pump
WHITECAVY wrote:DOHC_tuner wrote:WHITECAVY wrote:^^Right,
LOL I knew u were going to say that.
So you used a Quad 4 water neck? Thats what that guy means by "Ho" right?
^^ LOL, oh no I have the regular 2.4 waterneck, or were you directing that to Mcmoney?
The older quads are aluminum. Spencer has one on his w41. Shouldn't be hard to drill and tap for that line. Those are my plans when the motor gets built.
Okay im confused now. Iam aware the quad waterneck is not plastic....but im confused cause someone posted why not use the ho waterneck then,u agreed thats wat u have been,runinning.
the quad head's have a port for the 'bleeder' line whereas the LD9's is in the water neck housing. if you use the quad's you would then need to drill and tap for the LD9 line, or simply just use a bleeder screw and be done with it.
hell, i didnt even know it would bolt on. in fact iirc i read somewhere that said it did not... idk.
Same reason why im confused, I thought it didnt bolt on either. I will verify later this weekend.
I'm about to "billeted" everything
tensioner pulley
this is what you will never see
brake line through the the inner fender
power steering reservoir
crappy russell hose, fitting that leak all the time versus a nice crimped hose
new brake setup
but i'm going to put back the brake booster I'm not strong enough the drive this car now lol
omfg that tensioner pulley is SICK
