turbo project LN2 - Photos & Media Forum
turbo project LN2
Monday, January 26, 2015 5:45 PM
figured I would just put some pictures up step by step
Re: turbo project LN2
Monday, January 26, 2015 5:49 PM
if anybody has any information or anything I should look forward to. this is my first LN2 build. more pictures to come after I resize.LOL.....
Monday, January 26, 2015 5:53 PM
is that a 2.2 Non Eco tec ? if So i have a 1998 Cavalier 5-speed 2.2l i want to turbo , how much for the setup ? & how did u relocate dip stick ?
Monday, January 26, 2015 6:37 PM
Iv got about $600.00 in this kit. I use the oil tube for my return. Instead of going through tapping the oil pan. Save a lot of headaches. U just can't check you're oil. And I remove the value cover to change the oil. But if you know what you're doing it's. Not that big deal. Put 5 Quarts in and if it don't leak out. It won't evaporate LOL.....
Monday, January 26, 2015 6:41 PM
If it's a everyday driver I wouldn't recommend removing the oil tube. But mines just a weekend warrior
Monday, January 26, 2015 6:54 PM
Nice , ok i understand 600$ which i do work so that only takes about 2-3 weeks , but Honestly the headache for me is the Installation Fee's $$$ .. How much to install and for Dyno Tune ?
Monday, January 26, 2015 6:59 PM
Only thing I don't like about out motors is if/when you turbo, is the dipstick and/or the damn coolant line.
Monday, January 26, 2015 7:00 PM
Sorry can't help you there. I do all my work... I would charge about $500.00 don't know about anybody else.
Monday, January 26, 2015 7:01 PM
Coolant line??
Monday, January 26, 2015 7:03 PM
are you located in Florida ?
Monday, January 26, 2015 7:07 PM
Orange city Fl
Monday, January 26, 2015 7:11 PM
And remember mine is a non intercooled. I'm going to run water to air. Another $175.00
Tuesday, January 27, 2015 2:18 AM
You can easily keep the dipstick and coolant rail.
At $600 you better be ready to re-build this multiple times.
I don't want to rain on your parade, I'm glad your trying to mod the 2.2, but quality parts will make it last much longer.
My build is easily over $5000.
If you have any questions along the way, feel free to ask.
There are a couple good 2200 guys on here.
Tuesday, January 27, 2015 5:11 AM
I understand, the parts I have are not bad. Remember that just $600.00 for a decent turbo and a good use turbo smart 38mm Wastgate. I didnt talk about all the money I have in arp studs, 660cc inj. 255 intank, 1.7 rollers, head work, quiet list go's on and on...... But I do appreciate anybody that helps
Tuesday, January 27, 2015 5:22 AM
That is a sick setup. Thanks for the picks. Hey no A.C.. LOL
Tuesday, January 27, 2015 5:28 AM
I ran 12psi through a stock motor on cheap eBay parts for over a year with a "t04e" .63 turbo. Nothing ever really went wrong with that setup and it probably was in the 225whp range. Even my most powerful setup was on an off brand gt35.
I ran without a dip tube for the better part of three years lol.
If you keep the power under 275ish on stock motor there really are no surprises provided the motor is maintained and mechanically sound.
The tune is the part that matters.
I only started to run into issues when I went to big power and started running to 7k. And even then the thing never hesitated once I worked out the bugs.
I'd like to see what it does when you get it running.
"A car just isn't a car without a little blood, sweat, and beers." -- Shadowfire
Tuesday, January 27, 2015 8:29 PM
If anyone could tell me the best way to tune this thing that would be great....
Wednesday, January 28, 2015 3:23 AM
HP Tuners
Wednesday, January 28, 2015 9:04 AM
Not to mention someone that has Jbody tuning experience. I would not bring my car to someone who didnt.
cobalt, f-body, etc do not count when compared to J stuff.
Wednesday, January 28, 2015 3:23 PM
Got it out on a little test drive air/fuel looks good. Run great till it hits any boost it's almost feels like fuel cut or something. Any ideas???
Wednesday, January 28, 2015 3:50 PM
yea, if youre untuned youre running lean.
Wednesday, January 28, 2015 4:34 PM
yeah that's what it is I'm running lean and I have installed the fuel system yet I'm still running on stock fuel system that's why I haven't tried to push it very hard
Thursday, January 29, 2015 1:08 PM
Ok I installed a 255 intank and 60lb injectors. Now it won't even hardly run. I'm fine with that if all I need to do is tune. Does this sound right??
Thursday, January 29, 2015 2:31 PM
I understand that I need to tune this car. Regardless of what injectors I have. I'm only going to run 8lbs tops. I also have a set of 310cc what do u think would be better the 660cc I have or the 310cc??
Friday, January 30, 2015 5:07 AM
660 are way over kill for 8psi, regardless of the turbo size.
I would run the 310.
Im running 720 and pushing 25 psi from a TD05.
Im almost at 90% DC wich is higher than I want to be.
You need to reset you injector constant, and the tune will change the pulse width so proper fueling can occur.
I would stop running the car until you are tuned.
You can do major engine damage while running lean.
Stay out of boost, and keep your RPM's down if you have to drive this.
