How do I remove the headlights and the guard on my 96 2.2 - Newbies Forum
Wednesday, February 25, 2009 1:10 PM
Hello, I have a 96 2.2L and I'm wondering how I remove the headlights. I can't seem to get the shield off. How do I do that? Thanks!
Re: How do I remove the headlights and the guard on my 96 2.2
Wednesday, February 25, 2009 1:24 PM
the little "shield" that goes from fender to fender under the hood removes once you take out the little push pins holding it in..
use a small pair of needle nose pliers to get under the center button of the push pin,pull it up,once thats done the whole push pin pulls out.. I believe there are six of them... then the shield can pull out, once thats outta the way you can get to both of the screws/bolts holding the headlamps in, to take those out you need a 13mm socket..
you will need to lift the head lights up a little before they pull out of the fender/bumper area, there is a plastic peice that extends off the back of the housing that slides into a small hole that keeps it in place.., hope that helps, if i missed anything Im sure someone will clear it up for ya.
Monday, February 28, 2011 8:55 PM
How do I remove the headlights on my 98 cavi
98 cavalier
Custom interior
Custom CAI
NGK spark plug wire set
2 12 in alpine type 2
Monday, February 28, 2011 9:10 PM
^Look right above your post
Monday, February 28, 2011 9:33 PM
Yea I looked and remixes it's the exact same as the 96
98 cavalier
Custom interior
Custom CAI
Monday, February 28, 2011 9:34 PM
The little plastic pull tabs where can u get those to replace them in gta region
98 cavalier
Custom interior
Custom CAI
Monday, February 28, 2011 10:56 PM
you broke yours? how did you manage that lol..
Tuesday, March 01, 2011 11:28 AM
Gov wrote:The little plastic pull tabs where can u get those to replace them in gta region
Pocket them from any you-pull-it junkyard
Tuesday, March 01, 2011 4:51 PM
You can buy them at any parts store...
