97 cavalier horsepower question - Racing Forum
Monday, August 04, 2008 11:19 PM
i have a 97 cavalier with a 2.2 5sp that knocks i was going to rering and bearing it and was told to put pistons for a 98 2.2 in it and i would get some more horses and compression cause they change the heads from 97 to 98 and the 98 pistons will clear the 97 head has anyone done or heard of this? any info will be great. thanks for your time,
Re: 97 cavalier horsepower question
Wednesday, August 06, 2008 4:00 PM
the head change is true, but i'm not sure on the piston design.
it'll be gutless either way, I say just stick to what you got so you know for sure it'll work.
changing compression a significant amount (0.5 or more) will open up a whole new can of worms with your computer.. tuning will be required via HPT at the bare minimum.
Friday, August 08, 2008 8:11 AM
DaFlyinSkwir(LS61) /PJ/ OEM+ wrote:it'll be gutless either way
QFT
Saturday, August 09, 2008 9:56 AM
Compression will be through the roof, think 14:1-ish.
11 speaker JL Audio stereo setup for sale:
http://www.j-body.org/classifieds/audio/52021/
Monday, August 18, 2008 10:18 PM
Could you tell us why it would be so high? Does the 98 have domed pistons? I thought just the head was changed between 97-98.
Tuesday, August 19, 2008 12:11 AM
the 98 had higher compression than the 95-97, so whereas the pistons aren't domed, the dish is shallower, thus bumping compression higher.
that, and the combustion chamber size is much less than the older 2.2 I believe.
Tuesday, August 19, 2008 9:35 PM
97- has bigger dish, smaller chamber
98+ has smaller dish, bigger chamber
which is why stock compression is similar for all years
Wednesday, August 20, 2008 4:11 AM
so smaller dish smaller chamber more horses?
Wednesday, August 20, 2008 7:17 AM
Stewart Dyas wrote:so smaller dish smaller chamber more horses?
smaller dish + smaller chamber = uber-compression = uber-knock = uber-destruction
Saturday, August 23, 2008 7:45 AM
What would be the max usable compression? Could you use thicker head gasket and fly-cut some of the piston dome or is the whole idea QFT?
Saturday, August 23, 2008 1:56 PM
Well, you don't want to kill your quench/squish, so just let it go. Have your block shaved .022" instead.
