circle track - Racing Forum
circle track
Sunday, December 07, 2008 5:13 PM
anybody runnin the ecotach in a circle track car and also does anybody now where to get 13x7" wheels for these cars
Re: circle track
Sunday, December 07, 2008 5:15 PM
im sorry ecotech im sure yall would have known that but.
Re: circle track
Monday, December 08, 2008 2:06 PM
we ahve diamond make our wheels for circle track, they are a 13x7 2" backspace
Re: circle track
Thursday, January 08, 2009 6:06 PM
www.mrt-wheels.com They will make you any size,bolt pattern,and back spacing you want. Check out my stockcar in the Classifieds. Ray
Re: circle track
Saturday, January 24, 2009 5:21 AM
Finally some familiar territory. Ive been involved in a lot of race teams, mostly late models. Im building a street 01 cavalier. what do you guys run for suspension? is there any aftermarket upper and lower control arms available for my car? ball joints? do you guys run jacking bolts? do you run it unibody. if not what frame do you use?
Re: circle track
Saturday, January 24, 2009 1:24 PM
Re: circle track
Saturday, January 24, 2009 1:29 PM
Ive never seen a 4cyl late model. I dont do dirt alot.
Re: circle track
Saturday, January 24, 2009 6:46 PM
no we got to be all stock
Re: circle track
Monday, January 26, 2009 3:20 PM
on the 4 cyl late model it says its a tube frame from the fire wall back, did you guys make that or did you buy it?
Re: circle track
Monday, January 26, 2009 3:24 PM
its says 2.2l, is that the non ecotech? how much hp are you guys getting out of it?
Re: circle track
Wednesday, January 28, 2009 2:36 PM
we made it, we are a custom fab race car shop, non eco, 204 whp
Re: circle track
Thursday, January 29, 2009 4:15 AM
That's really good, considering the rules limitations you are working with. Many will say well look how he did this or that, but they don't realize the restrictions you are under.
That's 204 HP at the wheels! Look at the rules he's working under:
Northeast Mini Stock Tour.com wrote:Engine
1. Engines must be 8 valve, Hondas allowed 12 valve
2. Block must be stock for make
3. 2500cc Maximum displacement
4. .040 Maximum overbore
5. Stock Steel Flywheel, may be resurfaced
6. Any clutch may be used, but must be functional
7. No porting or polishing of heads
8. Valves must be stock size and weight
9. Head must be completely stock, NO SVO or TRD heads
10. Heads are allowed to be shaved
11. Must be flat tappet camshafts max lift .450 measured at valve, no roller cams allowed
12. Adjustable cam gears allowed
13. Flat tappet lifters, No roller rockers or lifters
14. Crankshaft must be stock, no knife edging
15. Pistons and Rods must be stock appearing. Flat tops may be used
16. Stock Type ignition only, no magneto
17. Starter must work
18. Holley 5200 or Weber 32/36 carburetor
19. Holley 350 may be used, in conjunction with a 50LB weight penalty
20. Fuel Injection is allowed, must be completely stock including air intake, throttle body, injectors and computer. All items can and will be tested
21. Max Compression ratio 12:1
22. Radiator may be aluminum, Must be mounted in front of engine
23. Headers will be allowed, headers must exit under chassis and not bisect firewall 1.5” maximum primary diameter
24. 2.5” maximum exhaust diameter
When you consider what he's limited to, it's truely amazing what he's done!
Re: circle track
Thursday, January 29, 2009 6:50 PM
says we cant port the head, but we do so that differs from the rule but other than that we are good to go, that carb by the way only flow 175 cfm
