 you are here: / home / forums / racing
Saturday, May 18, 2013
99 cavalier 3/10 asfalt race car help - Racing Forum
Autocross (Auto-X), Drag Racing, Road and Track Racing spoken here. Street racing, on the other hand, is NOT spoken here. This forum is for legal racing only.
Previous MessageNext Message
Saturday, June 18, 2011 7:24 PM
I"m looking for some help on getting my car to turn better in the corners. 3/10 mile paved track. straightaway speed is fine, it's the corners that are slowing me down. any suggentions/help would be appriciated in things that could help my performance. I'm really really new to this and any help is more than i know ....tks
Advertisement
Upgrade to premium membership to remove this ad.
Re: 99 cavalier 3/10 asfalt race car help
Tuesday, June 21, 2011 8:45 PM
what ur toe and camber set at?
Tuesday, January 10, 2012 3:16 PM
ive found that tire pressures will help you through the turns also. i race at a 3/8 mile asphalt oval and i know when the tire pressures are off it can be real tight or real loose. the track i race at has some real steep banking (32 degrees in turns i beleive) and i run 14.5 lbs in front left 18 in left rear 30 in right front and 28 in right rear. those pressures are on a 185/65r14 street tire tho as we arent allowed race tires
Wednesday, January 11, 2012 7:32 AM
I ran a 100 lap enduro on Saturday with RF 37, LF 34, LR 28, RR 34 and the car was pushing pretty bad. After I had a flat RF and LR at the same time I got the RF changed and left the rear flat and the car ran better than ever. I was also running two inches of stagger. So the next race on asphalt, I'll try a much lower LR pressure. Not a flat.
Kenny "Poppop" Brown
Wednesday, July 04, 2012 3:26 PM
Camber will help you a lot too. I run almost 2 1/2" on the RF (just shy of the tire touching the strut) and 3" on the left front. This is up from almost factory camber last year and made a world of difference! Put in as much camber as you are allowed. Also tire pressures and stagger will help as stated above.
Sunday, July 22, 2012 10:52 AM
what kind of tires are you running? i run a falken azinis, they stick amazing to the track, also put some caster in it drill your holes in your k-member on the left side back a little bit (1/8'' or so) and it should turn better
All Rights Reserved
