SEB for rear trailing arm camber and toe - Racing Forum
Monday, November 15, 2004 5:23 AM
Who's up for writing and SEB to the SCCA to permit use of shims to alter toe and camber on rear trailing arm vehicles up to 2 degrees?
If I can get enough SCCA member here to actually do it I'll go over to the SE-R, and integra forums and see if they'll participate as well. <br>
-Chris
Re: SEB for rear trailing arm camber and toe
Monday, November 15, 2004 8:47 AM
count me in <br>
see ya!
Monday, November 15, 2004 9:59 AM
ME TOO!!
Monday, November 15, 2004 5:17 PM
I'm down. <br>
Tuesday, November 16, 2004 4:18 AM
IamRascal wrote:Who's up for writing and SEB to the SCCA to permit use of shims to alter toe and camber on rear trailing arm vehicles up to 2 degrees?
I'd go to those forums now to generate support. It's too late to do anything for '05 rules, but could work for '06.
I'd also suggest that we do not limit the alignment specs. Let people run whatever they want. Add the shims to the STS ruleset and rework it for SP classes (has to be within factory specs now, but should also be whatever the driver wants.)
Either that or someone get GM to give us a TSB on shims being allowed to alter rear alignment. At least that way we could max out the factory specs, which would be well within the toe settings we need though does lack a little on the camber side (at least in my preliminary testing.) <br>
Lightweight honDuhs can kiss my fat Crapalier a$$
A new autoX ride for '08.....
Tuesday, November 16, 2004 3:35 PM
Or make a fake TSB..... jk <br>
Tuesday, November 16, 2004 7:17 PM
I'll tell the acura and sentra in my region to contact their respective sources. Has anyone here written an SEB before? <br>
-Chris
Wednesday, November 17, 2004 10:01 AM
I just e-mailed a former rc engine builder/ supervisor over GM performance division about it seeing i lost his phone number i will see what he has to say or what direction he can point me in <br>
see ya!
Wednesday, November 17, 2004 3:28 PM
IamRascal wrote: Has anyone here written an SEB before?
Nope, but the manner in which to write them is outlined in the rulebook (which I don't have a personal copy of) <br>
Friday, November 19, 2004 1:32 PM
Does anybody know for sure that a TSB does not already exist?
I had a conversation with Ken Rupp a few years ago when I ran my 89 cavalier at a divisional event and he said that he ran his sunbirds with a shim plates on the rear end.
If you don't know who he is, Ken is a national level autocrosser (he is currently doing GS with his Toyota) and in a previous life was the owner of a Pontiac dealership in Ocala, FL and now I think in the Atlanta area. My point being that he would have the resources to know if there is a TSB or factory documentation on rear shims for accident repair, and secondly, that as a well-known national driver, I am sure that his car was squeaky clean as far as legality is concerned.
So,,,,,,, there may be a TSB, or repair procedure already documented by GM.
My 2 cents concerning usage of those plastic shims:
1. The bolts securing your hub will tend to loosen by using the plastic shims - I am guessing do to cold flowing of the plastic. Less than confidence building when I am racing. I hate when my rear hubs fly off!
2. The rear end on a front heavy fwd vehicle isn't nearly as important as the front end - so why bother.
On the other hand, Ken and his son did pretty well using shims (SCCA national championship good), so I am hoping one of you studdly Cavalier jockeys will go out and do some autocross before and after experimentation and let us all know if this is worth a sh*t or not. Inquiring minds want to know.
Friday, November 19, 2004 2:18 PM
It should be allowed for any type of car with a similar rear axel. I would support that idea.
Friday, November 19, 2004 3:13 PM
what you need to do to get around the rules is to get into a wreck that happens to alter your camber around 2 degrees. <br>
<a href="http://www.j-body.org/members/speedvisioncavalier"><img src="http://www.j-body.org/registry/speedvisioncavalier/new%20sig.jpg"> </a><img src="http://www.precizion.org/animatedz.gif">
"What are we going to do tonight?"
"The same thing we do every night, try to make the SVC go faster!"
Friday, November 19, 2004 3:25 PM
Too bad he dosn't still own the dealership in Ocala. I'd beg him to help me out with some tires or something. Its like 30 min from my house. <br>
Tuesday, December 14, 2004 9:58 PM
14.8 SUSPENSION
A. Ride hight may only be altered by suspension adjustments, the use of spacing blocks, . . . .
So would the "shims" be ok if you called them "spacing blocks" ?
<br>
My 2k3 cavalier | Nebraska Region SCCA
Wednesday, December 15, 2004 12:18 AM
thats ride hight not alignment but i dont think anybody will protest anyway. <br>
see ya!
Wednesday, December 15, 2004 12:59 AM
Well they would effect ride hight to some degree.
<br>
Wednesday, December 15, 2004 10:43 AM
that is true i say dont tell and they wont ask <br>
see ya!
Friday, January 14, 2005 4:25 PM
if you think you cant spot 2.0 degrees or more of camber just from looking at the car, you havent been looking hard enough. i can see it plain as day on my Z24 on the front. <br>
Sunday, January 16, 2005 10:21 AM
^^but then look at all the other cars running out there and your car will blend in i just got the rear shims from NOPI my self so seeing that this is going to be my second season i will not finish that close to the top for anybody to be protesting me anyways <br>
see ya!
Thursday, February 03, 2005 9:14 AM
novaracer wrote:^^but then look at all the other cars running out there and your car will blend in i just got the rear shims from NOPI my self so seeing that this is going to be my second season i will not finish that close to the top for anybody to be protesting me anyways
Unless I drove the car of course.
Monday, February 07, 2005 11:25 AM
Has anyone checked with the body shop guys, I talked with one a guy I work with and he indicated that to repair the rear toe and camber the body shop's will adjust with a porta-power.. if the axle is not too bad..
Thursday, February 10, 2005 12:16 PM
Any movement on the composition of this letter??
Friday, February 11, 2005 8:57 PM
i will check with the local chevy dealership body shop monday
see ya!
Tuesday, March 08, 2005 7:49 PM
I'm a GM Tech...I'm off tomorrow, but I can check Thursday, pretty easy.
Josh Hess
SCCV #222
www.sccv.org
www.vermontracing.com
Wednesday, March 09, 2005 7:50 AM
see ya!
