high a/f - Tuning Forum
high a/f
Tuesday, February 16, 2010 9:45 AM
I just got the AEM UEGO wideband and have been using it for a few weeks now, The thing is is that it shows an average a/f ratio of high 15's at idle. But it also oscillates really bad. Is this normal?
15.0 @ 90mph with only a intake and exhaust.
Re: high a/f
Tuesday, February 16, 2010 6:18 PM
at idle and normal driving the ECU targets 14:7:1 AFR's.
Re: high a/f
Tuesday, February 16, 2010 9:46 PM
Is it bad if it idles lean though?
Re: high a/f
Wednesday, February 17, 2010 3:10 AM
Jason Brantner wrote:Is it bad if it idles lean though?
No, it is meant to.
Re: high a/f
Thursday, February 18, 2010 7:27 PM
ok, good, I just assumed it was bad when I pulled my cap off my cutout and it idles between a 16.5 and 17 afr.
Re: high a/f
Monday, February 22, 2010 3:42 PM
Thats strange, my cut-out has no effect on my AFR at idle.
How close is your wideband gauge to your cut-out?
Probably have some air coming back into your exhaust system and your wideband is picking it up.
Re: high a/f
Thursday, February 25, 2010 5:12 AM
just curious, kind of on topic. My car runs a little rich, like 14.1-14.6 on the highway around 3k, and is always changing. Is that an acceptable range, or should it always be spot on around 14.7?
Re: high a/f
Thursday, February 25, 2010 7:50 AM
SpeedyPip wrote:just curious, kind of on topic. My car runs a little rich, like 14.1-14.6 on the highway around 3k, and is always changing. Is that an acceptable range, or should it always be spot on around 14.7?
acceptable
Re: high a/f
Thursday, February 25, 2010 8:25 AM
My cutout is back by my rear tire. Its not close to my wideband at all
Re: high a/f
Tuesday, March 02, 2010 9:31 PM
shouldnt affect your wideband at all I would think... Unless the cutout is just allowing the gases to escape more rapidly thus not getting an accurate reading. Im just taking a wild guess tho so dont take my word for it. That's weird tho...
"You can only feed them semen for so long before their legs fall off."
Re: high a/f
Wednesday, March 03, 2010 11:15 PM
15s is fine for idle, in fact I know alot of people with evos that actually have it leaner at idle
Your car will never run a consistant AFR while crusing it will bounce around, for cruising 15s is fine, pity our pcm doesnt fully support lean cruise
Re: high a/f
Sunday, March 07, 2010 1:57 AM
Now it has a new issue. I just a header back full exhaust and intake and when I am at WOT around 5800rpm, the wideband pegs out lean. Shouldn't it run pig rich if my injectors hit 100% duty cycle?
Re: high a/f
Sunday, March 07, 2010 5:26 AM
What else are you running besides your exhaust and intake?
Re: high a/f
Sunday, March 07, 2010 6:48 AM
Jason Brantner wrote:Now it has a new issue. I just a header back full exhaust and intake and when I am at WOT around 5800rpm, the wideband pegs out lean. Shouldn't it run pig rich if my injectors hit 100% duty cycle?
Just because your injectors are at 100% duty cycle doesw not mean your car should be running correct. In fact this could be a reason why you are not.
What AFR is it at before 5800, and what does it go to at 5800?
Re: high a/f
Sunday, March 07, 2010 2:42 PM
It will go pig rich from 5k to 5800 then it will peg out lean. And it will stay pegged out lean until it idles for about a minute. Even then it idles around 16.5-17
Re: high a/f
Wednesday, March 10, 2010 3:52 PM
So now my wideband always shows its pegged out lean. Sometimes goes back down but after 4k rpm it goes back to pegged out lean again. Is this a sign of a bad O2 senspr on my wideband?
Re: high a/f
Friday, March 12, 2010 7:00 PM
Duty cycle has absolutely nothing to do with AFR, thats just how hard the injectors are working. If they arent sized properly you can actually damage them running too high of a duty cycle. By contract running too much fuel pressure can also damage them. To me it sounds like your tune needs some smoothing out and possibly bigger injectors, what size are you running right now?
Re: high a/f
Saturday, March 13, 2010 3:27 PM
Thats the thing. Stock injectors, stock tune. Its a wideband issue. I am still looking for a tune
Re: high a/f
Thursday, March 18, 2010 3:39 PM
That sounds like definitely a wideband issue.
What are you using for a ground for your wideband. I know the LC1's are bad for grounding issues.
Re: high a/f
Friday, March 19, 2010 8:58 PM
Under the dash bracket. Everything worked fine before. Wouldnt a bsd ground make the wideband shut off. I thought maybe a bad O2 sensor
Re: high a/f
Saturday, March 20, 2010 6:49 PM
I was right. I replaced the sensor and all is good
