Putting a 2.4l in a 93 gtz with a 2.3??? - Tuning Forum
Tuesday, October 18, 2011 5:33 PM
I have a 96 2.4l lowerend with the 2.3 oil pump swap, top end is all 2.3l. I want to put my motor in a 93 beretta gtz. My biggest problem is with the CPS (crank postion sensor) not sure what my options are here? The rest is no problem. Any help from anyone would be great. Thanks
Re: Putting a 2.4l in a 93 gtz with a 2.3???
Wednesday, October 19, 2011 6:22 AM
Cps shouldn't be a problem since the 2.4 crank is in the 2.4 block. The problem only comes up when you make a stroker cus the censor position in the block and on the crank are different between the engines. Should still read the same as long as you don't mix n match.
Wednesday, November 02, 2011 2:35 PM
What Zs said.
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
RACER X - '78 Opel Kadett W41 Swap
Saturday, November 12, 2011 6:31 PM
Maybe Im wrong but isnt a 2.3 crank 15 degrees? A 2.4 a 0 degreee? Is the ecm going to adjust itself for that? Thanks.
Saturday, November 12, 2011 7:59 PM
The notch is like that on the crank but the hole in the block is placed accordingly based on the notches in the crank. Which is the reason you have trouble with a 2.4 crank in a 2.3 block. However as far as swapping a whole 2.4 engine to a 2.3 engine the sensor will will work properly because it is only meant to read 1 revolution at a time and will do so perfectly as long as the mark on the crank is referenced correctly with the mounting point on the block.
Saturday, November 12, 2011 8:19 PM
fill the notches in the crank and cut new ones for proper timing.
Come join us over on the Olds Quad 4 and Twin Cam Facebook group!
Saturday, November 12, 2011 9:37 PM
Hes not talking stroker, just putting a 2.4 in a GTZ
Saturday, November 12, 2011 9:53 PM
wow, i think Zs is the only one that gets it lol
hes gonna be fine..he has a 2.4 crank in a 2.4 block..itll be FINE...the harness will still plug in and run all the same.
now of course hell have to do some tuning to the gtz pcm to accommodate for his mods...but the CPS is not going to be an issue. no change needed. period
