LD9 2-bar on LK9 swapped cavalier (false knock?) - Page 2 - Tuning Forum
Re: LD9 2-bar on LK9 swapped cavalier (false knock?)
Friday, March 22, 2013 7:59 PM
We did use a 2200 ECU, but loaded a LD9 reflash so it would be the same as what you have now.
We would get spikes, but problem being is Roberts knock sensor was never connected properly. Since we used a 2001 2200 ECU it had the one wire knock sensor, but the LD9 reflash is for a 2 wire knock sensor. I have my doubts weather we were getting correct readings. We were looking into swapping the wiring connectors to make it be correct. Never got to that.
Saturday, March 23, 2013 7:41 AM
I hate knock....im reading it on my SS/TC......I dont even want to know what my Z24 will be reading once im done with it.
I was logging up to 8 degees of KR. Installing a intake without a updated tune was worse!
Anyways im glad you figured it out. Ish happens when modifying and upgrading....you learn from it.....and get better.
GMR has got nothing on this
Wednesday, May 29, 2013 12:39 PM
what are the major differences if any, between the LK9 and LSJ options?
It sounds like Im going to have a real fun time trying to get timing down with any motor other than the L61...but thats why you guinea pigs..err i mean fine fellow jbody owners are there to help
Im going to try to go through Evils builds and see if this info is in there, but i didnt at first. More options is always good as there are healthy rebuilt Saab motors to be had which expands your odds of finding a decent upgrade option.
04 Cav. 2dr. 5spd. My DD. 'Nuff said.
Wednesday, May 29, 2013 5:03 PM
Lsj and lk9 are essentially the same motor (lsj's even have Saab stamps on them). Only difference is the LK9 has a hole in the rear girdle to plug from the turbo oil drain line, and the intake side of the head has m6 holes for the manifold like the l61, as opposed to the m8 on the lsj. And the LK9 has slightly more aggressive cams (I think a bit more duration).
All in all, same motor, and in my opinion, the Saab is probably less likely to have been beaten on the lsj
Friday, May 31, 2013 11:37 AM
yeah im definitely not wanting to deal with more broken bolts for the intake manifold to head...m8 only for me please when dealing with the m62 blower manifold!
I just hope if i hear back on the LSJ motor soon and i get it, my HPTuner guy can work some magic on my 05 Ecotec ECU with this LSJ setup. Its already dialed in for the set up i had before but obviously it'll need some tweaking.
Raf, how are you doing on your HPT knowledge..you going to start helping others with a tune?
Friday, May 31, 2013 4:43 PM
One word of caution bud.....The tune wasnt "dialed" in. Please for the love of your new motor....take it easy on it until the tune actually isnt knocking like a mofo.
Wednesday, March 01, 2017 2:21 PM
Anyone know why exaxctly does an LD9 reflash produces false knock on an ecotec? I swapped and also did the knock fast attack adjustment in case, but was looking at rockauto pictures of the sensor on LD9 and ecotec and its seems to be the same. (Same part number also IIRC).
Is because of a different location and internal knock detection maps are adjusted to fit the location ect?
Thanks for the info
Wednesday, March 01, 2017 4:39 PM
Thanks for the info
My guess would be the difference between the steel block and aluminium block.
Tuesday, September 19, 2017 6:54 AM
My guess is the harmonics of both engines are different. Has anyone compared the L61 to the LD9 for the knock sensor settings?
Tuesday, September 19, 2017 10:12 AM
I mean one block is iron and the other is aluminum. That has to be worth something.
"In Oldskool we trust"
