Crank & Cam Position Sensors - Tuning Forum
Thursday, April 18, 2013 7:01 PM
Hey guys, I just need to verify something about the Cam and Crank position sensors on an LD9 (specifically a 98-99)...
Are the Crank and Cam position sensors HALL type sensors or MAG type sensors?
I think they are Hall but I want to be sure as this affects how I wire a piggyback in.
Thanks for any help!
-Chris-
-Sweetness-
-Turbocharged-
Re: Crank & Cam Position Sensors
Friday, April 19, 2013 3:28 AM
ask Brad.
Friday, April 19, 2013 5:22 AM
how would i know? i didnt graduate from FU tuning - school of the fine arts.
Listen to our new single, called CRY CRY CRY, by John H.
Friday, April 19, 2013 6:38 AM
Well you see, to know how other sensors work, and what they are suppose to do.
Chris I'm pretty sure your right. I think it says in my Haynes manual and will look later today.
Friday, April 19, 2013 7:07 AM
Thanks John, if you can let me know what page you may find that on I just DL'd the Haynes manual yesterday looking for the wiring diagrams and didn't see any mention of the sensor styles for these two.
-Chris-
-Sweetness-
-Turbocharged-
Friday, April 19, 2013 8:02 AM
i didnt read up on every sensor john. i read up on the one that mattered in our situation, the lambda sensor.
i am sorry i am not an expert on every sensor in the engine. when can i start classes at FU?
Friday, April 19, 2013 4:53 PM
easiest way to tell.
2 wires = Variable Reluctance sensor (mag)
3 wires = Hall effect
the reason hall effect has more wires is because it requires a 5v reference
also worth noting is it outputs a square wave, so it requires no external circuitry
VR sensors output a SIN wave that needs to be interepreted and translated into a square wave by electronics built into where the signal is going (in our case the engine controller)
you normally can't swap one for the other (hall effect vs. VR) because of the different signal outputs.
Friday, April 19, 2013 6:54 PM
Awesome thanks for the info PJ, now to pull up the Haynes manual and check the wiring to both those sensors.
Time to start drawing up some wiring diagrams for the car...
-Chris-
-Sweetness-
-Turbocharged-
Friday, April 19, 2013 7:32 PM
Hmm it looks like the crank position sensor is 2 wires (mag) and the cam position is 3 wires (hall)... anybody want to confirm?
-Chris-
-Sweetness-
-Turbocharged-
Friday, April 19, 2013 11:05 PM
-Chris-
99% of the time, that's the case
ie. crank = VR and cam = Hall
LSJ is the same way
Saturday, April 20, 2013 6:32 AM
-Chris-
Crank is certainly VR.
If this info is for a standalone, also be aware that the leading edge of the crank pulse is inverted because our 6+1 trigger wheel uses notches for crank angle rather than teeth.
The Cam is probably Hall effect, but I'v never monitored this signal before, so I don't know for sure. Like PJ said, if it has 3 wires, then it's a safe bet it is.
I have no signiture
Saturday, April 20, 2013 7:31 AM
What I saw in the haynes manual is in section 6-8, but ti does not say which we have but talks about Hall effect (3 wire) sensors (crankshaft, camshaft).
Monday, April 22, 2013 4:02 AM
I'm about 90% sure the Cam sensor is a hall effect sensor, and the crank is a Variable Reluctance sensor.
