turbo tuning - Tuning Forum
turbo tuning
Monday, July 08, 2013 11:37 AM
I'm looking for someone with HPTuners and an 97 Cavy 2.4 license.I'll buy the credit myself if anyone just has the software.I'm not looking to pay out the ass, I need a full tune. I live in south texas rio grande valley.
Specs for my car:
Fully built
Turbo
Low compression
3bar map sensor
Aem wideband
750cc injectors
And all the good stuffs.....
Re: turbo tuning
Monday, July 08, 2013 2:57 PM
Why a 3 bar map sensor?
Re: turbo tuning
Monday, July 08, 2013 5:44 PM
Planning on boosting 14-18psi and want to be on the safe side...
Re: turbo tuning
Monday, July 08, 2013 5:55 PM
Our computer does not use map for fueling except for idle fueling, and some rare 97 ecu's. still the rare 97 ECU that does use map, the 3 bar sensor would make the resolution way off.
Re: turbo tuning
Monday, July 08, 2013 6:00 PM
So the 3 bar will affect the tunning?
Re: turbo tuning
Tuesday, July 09, 2013 4:33 AM
Why 14-18psi?
Re: turbo tuning
Tuesday, July 09, 2013 1:47 PM
On our ECU will affect the timing more than anything, and it could hurt more than help.
Re: turbo tuning
Wednesday, July 10, 2013 12:17 PM
I'm sorry but:
"Not looking to pay out the ass"
and
"I need a full tune"
don't go well together in a sentence when talking about a built engine with a completely different compression ratio than stock. You're right - you do need a full tune... but you also need to pay out the ass to get it as your tune is going to take a LOT of time and that's before it even gets strapped down to a dyno for final WOT tuning.
EVERYTHING about your stock maps/pcm is now null and void... everything needs to be done from scratch. It's not easy and a tuners time doesn't come cheap.
As mentioned, you won't be using that 3 bar map sensor. You won't even be using a 2 bar map sensor. You are stuck with a PCM that doesn't read boost, actually... unless you want to do a full harness/pcm swap.
Good luck.
-Chris-
-Sweetness-
-Turbocharged-
