I read somewhere if you disconnect to o2 sensor that it would read your tables with out the computer trying to compensate. is this true? Will this work for ve tuning?
Read the stickies, they have the information you're looking for.
Yes, but you can disable closed loop which is what most will do.
i do some tuning with closed loop working as well.
I ask because I've been trying both. If i did it in open loop the commanded afr would be 11.5. In closed loop for some reason it would not stay running, when would do ltft+stft and multiply by a percentage it would lean out in idle and it not try to fix its self.
Why are you doing that? When I tune in closed loop I still use my wideband. I do not use LTFT and STFT.
If I recall correctly....that is how the LNF cobalts are tuned.
They have a factory wideband, we do not.
How do you tune in closed loop with a wideband? If its trying to always to set it to 14.7 wouldn't this skew the numbers? Do I just tune it like its in open loop?
exactly. Use your histograms. I will set it up to only ready 14:6 target, so anything in PE does not log.
Just double checking this is filtering regular [sens.121]<14.6. This is filtering in PE [sens.121]>14.6. Does this look right or do I have it backwards.
I tried it today and it did the same thing, it would just die or go super lean. I think i might have a vacuum leak or a bad tp sensor. TP volts went between .47-.51 at idle and 4.43 at wide open. Any ideas?
