96 to 95 PCM swap - Tuning Forum
96 to 95 PCM swap
Sunday, March 26, 2006 3:44 PM
Hey folks, I have a 96 fully built turbo car already, but I was kicking aroudn the idea of swaping in a HO or a W41 2.3, and building it with the 2.4 crank and boosting the &$%@ out of it instead of going anymore forward with my 2.4. I was wondering how hard the swap is and if all of the gauge wiring and all of taht crap is the same. I have searched but couldnt find anything but I am sure taht some1 has done this as we all know the 95 pcm can be chipped!!! But anyway, I just hope that this is a mere take out 2.4 and 96 pcm, put in built 2.3 and 95 pcm and done. Please let me hear some insight!! Thanks people.
Re: 96 to 95 PCM swap
Sunday, March 26, 2006 5:19 PM
You can run your 2.4 with a 2.3 ecm no problem. But since your 2.4 is already boosted, I'll say from experience, to stick with the 2.4. There's NO manifold for the 2.3 turbo. You have to build one yourself. Then the engine will most likely need to be rebuild or at least the head will need to be changed with the head gasket.
It's up to you but turboing a 2.3 is a P I T A. You 2.4 is already turbo so just build a 2.4 and turn up the boost.
Gilles
2.3 Ho
Sunday, March 26, 2006 5:21 PM
95 OBDI
96 OBDII
Engines where setup differently to account for the new sensors.
Tach Out Motorsports
Option D Inc.
Sunday, March 26, 2006 7:17 PM
2.4 is already built!! lol....I am just obsessed with the 2.5 stroker. I will more than likely buy a 95 cavalier z24 5sp and built taht motor n/a. Since the 95 cavy motors arent w41 or HO, if I put one of those motors in the car, do they sell chips to run them, or do they keep the same PCM, I am by no means a 2.3 guru, but they interest me a hell of a lot. Considering I will be building the motor in the first place, I could possibly keep the motor, but just put a 086 head on the built motor, then just get a chip for the PCM. Now I just need to get the funds to buy a 95 z24...lol....they arent the easiest things to find anyway...taht is why I think it would be easier to get a 96 and do the PCM swap, u see 96 z24's all over the place.
Sunday, March 26, 2006 8:01 PM
yes they make chips for them and yes the stock 95 pcm will run any of the quad engines...the only place i know of though that sells chips for the 95 pcm is MANTAPART...yup..you guessed it...cost ya about 250 and who knows what kinda wait...even if they are worth it
Wednesday, April 12, 2006 2:43 AM
That's not true. Actually we're working on a programable solution for the 95 pcm right now. Moates.net sells a general programmer that when used with RT Tuner can tune any chip settings in the ECU.
Did you need a 95 ecu, i can probably find you one. Or at least, help you tune your Q4. Email me kyanox@yahoo.com for details.
Wednesday, April 12, 2006 5:45 AM
C Smyth wrote:That's not true. Actually we're working on a programable solution for the 95 pcm right now. Moates.net sells a general programmer that when used with RT Tuner can tune any chip settings in the ECU.
i want more info...
i have a 97z and i have done the 95 ecu swap. i just got a mantapart HO chip.
But i would like to learn more on that topic....
thanx
Wednesday, April 12, 2006 11:33 AM
you finally got the chip? good to hear.
96 OBD 2 ~ 95 OBD 1
C-1 Black ~ C1=Blue C2=White
01-Gray~EGR Disconnect
02-Pnk/Blk~Inj 3 C2-4
03-Pink~Ign #1 C1-9
04-Empty
05-Pink~EGR Ign Feed Disconnect
06-DkBlu~TP snsr Sig C2-29
07-LtBlu/blk~Inj 4 C2-2
08-Yel~ECT sig C2-9
09-LtGrn~Map sig C1-3
10-Empty
11-Empty
12-DkGrn/Wht~Fuel Pump C1-1
13-Ppl~O2-1 Sig C2-12
14-Tan~O2-1 Ref Low C2-6
15-Ppl/wht~HO2-2High Disconnect
16-Tan/wht~HO2-2Ref Disconnect
17-Empty
18-Pnk~PSM A Disconnect
19-DkBlu~PSM B Disconnect
20-Yel~PRNDL B Disconnect
21-Gry~PRNDL C Disconnect
22-Brn~EGR Sig Disconnect
23-Empty
24-Red~Cam Pos Feed Disconnect
25-Pnk/Blk~Cam pos Gnd Disconnect
26-Empty
27-Gry~F Field Sig C2-28
28-Yel/Blk~Trans Temp Disconnect
29-Red/Blk~A/C Ref Pres C2-30
30-Tan~IAT Sensor sig C2-10
31-Empty
32-Empty
C-2 Gray/Clear
01-Blk/Wht~PCM Ground C1-25
02-Pnk~Ign #2 C1-4
03-Orn~Batt Feed C2-11
04-LtGrn/Blk~IAC B low C2-16
05-LtBlu/Blk~IAC A low C2-32
06-LtBlu/Wht~IAC A high C2-31
07-LtGrn/Wht~IAC B high C2-15
08-Tan~Oil Press C1-26
09-Yel/Blk~Coolant sig C2-26
10-Blk~Inj 1 C2-2
11-LtGrn/Blk~Inj 2 C2-4
12-Orn/Blk~Ground C1-6
13-Gry~Volt Ref C1-7
14-Blk~Ground C1-22
15-Tan~serdata OBD2 Disconnect
16-Red/Blk~Ign Ref Low C2-22
17-Brn/Wht~Cam Pos sig Disconnect
18-Empty
19-Brn~Low oil sig C2-27
20-Empty
21-Blk/Wht~PRNDL A Disconnect
22-Brn~Gen Lamp sig C1-24
23-Tan/Wht~PCM Ground C2-23
24-Red~PSM C Disconnect
25-LtBlu/Blk~Cruise on C2-25
26-Wht~PRNDL P Disconnect
27-Empty
28-Yel~TCC Release Disconnect
29-Gray~5 volt ref C1-23
30-Ppl~ Serial Data C1-20
31-Empty
32-Ppl/Wht~7xRef sig C2-17
C3 Blue
01-DkGrn/Wht~VSS Output C1-8
02-DKGrn/Wht~A/C Relay C1-10
03-DkGrn/wht~Evap purg C1-16
04-Empty
05-Wht~ Evap Vent No Pin Found
06-Empty
07-Ppl~Vss Low C1-21
08-Yel~Vss High C1-18
09-DkBlu/wht~TISS LO Disconnect
10-Red/Blk~TISS HI Disconnect
11-LtBlu/Wht~VBS LO Disconnect
12-DkGrn~Cooling Fan C1-12
13-Empty
14-DkGrn~Cruise off C1-11
15-Empty
16-Red/Blk~VBS HIq Disconnect
17-Blk/Wht~PCM Ground C2-24
18-Pnk~Ign #3 C1-4
19-Brn/Wht~MIL control C1-13
20-Wht~Tach Lead No Pin Found
21-LtGrn~Shift B Disconnect
22-Brn~TCC PWM Disconnect
23-Yel/Blk~ Shift B Disconnect
24-Empty
25-Ppl~TCC BrakeSwitch Disconnect
26-Empty
27-DkBlu~Knock Sensor C1-2
28-Empty
29-Empty
30-DkGrn~FuelTank Press Disconnect
31-Orn~Ign Control 2 C2-19
32-Wht~Ign Control 1 C2-21
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Wednesday, April 12, 2006 3:23 PM
yup, i had to file a claim with paypal, then 4days later he shipped it and i received it yersdertay.
Wednesday, April 12, 2006 9:14 PM
Again, mantapart can send you a chip for the HO, but it's not really a tuned ECU file. What I'm doing with moates.net is tuning cars using a programmer and datalogger with realtime logging. Essentially, i can monitor and log every single parameter in my ecu, and adjust it accordingly to reach the IDEAL settings.
I can even use wideband o2 to get my settings locked in.
Thursday, April 13, 2006 6:32 AM
C Smyth wrote:Again, mantapart can send you a chip for the HO, but it's not really a tuned ECU file. What I'm doing with moates.net is tuning cars using a programmer and datalogger with realtime logging. Essentially, i can monitor and log every single parameter in my ecu, and adjust it accordingly to reach the IDEAL settings.
So this DOES work for a 95 sunfire? I have a 95, and i am going turbo soon. My plan was to use megasquirt. Would this work well enough? will it work with a 2 bar or 3 bar map sensor?
