ECM/PCM for my car - Tuning Forum
ECM/PCM for my car
Friday, September 16, 2005 5:59 AM
how come when i call dealers the part numbers are the same for a 1995 2.2 ECM?
but yet people say there different from manual to auto..
do i really need to get a different ECM? and how can i tell if the one i get is right?
SPONSORED BY: CAVALIER EXTREME
Re: ECM/PCM for my car
Friday, September 16, 2005 8:11 AM
Auto/Manual ECU/PCM's are the same, its the programming thats different. If you buy a dealer ECU, it comes blank (for all intensive purposes), and they put the appropriate CAL on it so your car runs.
Friday, September 16, 2005 8:58 AM
so if i buy a ECM from GM, will it come programmed already if i say my car is a manual
Friday, September 16, 2005 9:07 AM
you can just changed the E-prom if you think you have a problem with your ECM. You have OBDI so you can change it.
Gilles
2.3 Ho
Friday, September 16, 2005 10:49 AM
so if i buy a used manual ECM it will alrdy be programmed? just plug it in and go?
Friday, September 16, 2005 10:59 AM
okay i called the dealer...
they said theres one part number for the 2.2 and one for the 2.3..
i dont understand how it can be different if they have the same part number?
Friday, September 16, 2005 11:11 AM
okay,
i called another GM dealer...got it all sorted out and explained...
i can just get my PCM flashed...and supposively NAPA can do it without having the car there...
but what if NAPA cant, and i put my tranny in and all, would it hurt to plug my PCM in until i get to the dealer? running?
Friday, September 16, 2005 11:40 AM
if you have a blank PCM the car won't run. won't start. won't do anything.
Friday, September 16, 2005 11:56 AM
no i mean having my auto PCM in with my 5 speed tranny...
just trying to avoid getting my car towed to a dealer...so i was wondering if i could drive it like that
Friday, September 16, 2005 11:26 PM
hmmmm... well for one your idle will be incorrect. for two, you won't be able to get the key out of the ignition because it will be expecting the car to be in PARK. i'm sure there are others
Saturday, September 17, 2005 9:43 AM
So you're saying the shift interlock is controlled by the ECM? Thats the first I've ever heard of a computer controlled ignition switch.
