1998 ECU in a 1995 ? - Tuning Forum
Wednesday, September 21, 2005 10:12 AM
Would a 1998 2.4 ECU work in a 1995 2.3 manual car?
Re: 1998 ECU in a 1995 ?
Wednesday, September 21, 2005 10:21 AM
i do not believe so....not only would it have to be reprogramed, i don not think the connectors are even the same
Wednesday, September 21, 2005 10:44 AM
no, 1995 is OBD1 & 96+ is OBD2
so DEFINATELY NOT.
"Your Premier Source For Automotive Neon & Accessories!"
Wednesday, September 21, 2005 10:52 AM
no worth it!!! 95 manual is chippable!! check out your chip options
Wednesday, September 21, 2005 11:51 AM
is there anyway to piggy back the computers?, i pu a GTZ engine in my 1998 cavalier i started it up and runs fine i haven't drove it yet, but from what i heard is that the computer will go into a "limp mode" when i drive it and it wouldn't perform as it's supposed to ....any ideas?
Wednesday, September 21, 2005 12:31 PM
xganjamanx wrote:is there anyway to piggy back the computers?, i pu a GTZ engine in my 1998 cavalier i started it up and runs fine i haven't drove it yet, but from what i heard is that the computer will go into a "limp mode" when i drive it and it wouldn't perform as it's supposed to ....any ideas?
If you put a piggyback system on your computer and it is INSTALLED properly, you will not run into limp mode. I know from personal experience because had a bad install on my SAFC-2 (person didn't souder the wires) and the wires came loose on the highway and ran into limp mode and stalling out.
Check out piggy back setups like Megasquirt, Greddy E-manage or Apexi SAFC-2
Wednesday, September 21, 2005 12:41 PM
thanks for the info
Wednesday, September 21, 2005 12:50 PM
xganjamanx wrote:thanks for the info
You're welcome
Wednesday, September 21, 2005 1:05 PM
ohh as well what about the engine codes how will the piggyback system get rid of those?
Wednesday, September 21, 2005 1:41 PM
xganjamanx wrote:ohh as well what about the engine codes how will the piggyback system get rid of those?
They won't get rid of codes. Their main purpose is fuel or iginition (or both).
The only way to get rid of codes is through a OBDII Scanner, reseting your computer by disconnecting your battery or actually fixing the problem.
