I am looking for tuning software for the 02-05 ecotec sunfire. anyone hear of any yet?
yeah weve heard alot about single systems like emanage or aem plugandplay but is there something not dealership garage expencive that can flash the car?
HP Tuners
Joshua Smith wrote:I am looking for tuning software for the 02-05 ecotec sunfire. anyone hear of any yet?
Well, it depends what your goal is...All motor or Turbo/Supercharged.
SAFC-2 and E-Manage is good for all motor setups
Megasquirt and (the soon to be released) Hahn Portfueler will be good for boost
HP Tuners software...no idea when it will be out.
By the way, you should only tune if you have an Wideband O2 or take your car to a dyno.
Those are all crap if they can't raise the rev limiter. That's where real n/a power is..
JimmyZ wrote:Know first....THEN speak.
maybe you should follow your own advise..
he said power.. as in horse power and if you look into the equation, then you'll see that RPM's play a major role in the power you make. also it is well known that the ecotec is capped too low. it is still making power when it hits the limiter. also gm has stated with merely changing springs much higher rpms are obtainable. they feel confident that the top end can support flow for the increased rpms and therefore a increased power.
next time you decide to chime in and put somone elses comments down do your homework, otherwise you sound like a standard ignorant flamer..
Jrobz23 wrote:JimmyZ wrote:Know first....THEN speak.
he's right jimmy. not to mention, we have to remember that the designs of GM pushrod and DOHC motors are far different than the designs of Honda SOHC and DOHC motors.
all very ture and i do know and agree that gm put it there for the other 98% of cavalier drivers, not us. but it would be great for the ACTUAL tuner folks if there was some tool that could easily move (prefer) or remove the redline.
i only chimed in cuz i thought you were a little harsh... no disrespect.
Out of the SAFC-2 and the E-Manage system, which one is less likey to trow codes
Beware the Rouge Dragon.
khaserwolf wrote:Out of the SAFC-2 and the E-Manage system, which one is less likey to trow codes
You are comparing apples to oranges. It's the PCM that throws codes.
Jrobz23 wrote:also it is well known that the ecotec is capped too low. it is still making power when it hits the limiter. also gm has stated with merely changing springs much higher rpms are obtainable.
Just so you know, camshafts play a role in making power in higher RPMs and shifting your powerband upwards, not just springs.
I fully agree with Jimmy Z, if there wasn't a rev limiter, there would be tons of people who would probably rev out to 8 grand thinking they make power all the way to that point. Fact is, stock ecotec motors won't make power past the limiter and in some cases stop making power just before the limiter.
Jrobz23 wrote: also it is well known that the ecotec is capped too low. it is still making power when it hits the limiter.
Ummm, no. The ecotec stops making power 5500-6000 (5750) rpm redline at 6250-6500 rpms
