Need Injectors, look here - Tuning Forum
Sunday, July 02, 2006 2:28 AM
ok, so I only looked up stuff that will fit 2.4's...... but thats cause their pretty much all that I deal with.
For the 96-99 2.4....
LT1 #5235236 (350cc)
For the 00+ 2.4......
Ford Red Tops (320cc)
Ford Green Tops
User Note: The Bosch Green Top 558 is a highly efficient fuel injector that incorporates a straight stream fuel delivery. Best used in engines with single-intake valves.
(Actual bench flow-test indicates 45lbs/hr (470cc) at 3 bar).
Volvo "Green Giants"
User Note: The Bosch 0280155968 is a highly efficient fuel injector that incorporates a wide-cone fuel delivery. Use in engines with single- and multi-intake valves.
(Actual bench flow-test indicates 42.9lbs/hr (450cc) at 3 bar).
Info HERE
Find what you want, then do a google search to find dimensions (some are listed on that site above)
Edited 2 time(s). Last edited Sunday, July 02, 2006 2:30 AM
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Re: Need Injectors, look here
Sunday, July 02, 2006 8:58 AM
Very nice, but do you have any info as to whether any of these will connect directly to the stock wiring harness? Or know of any that will?
Sunday, July 02, 2006 2:24 PM
I have both the old style and new style plugs on my harness....... so I'm not to worried...... but *most* of the slim body injectors use a connector like the 00+ (or close enought to make work), while just about all the fat body injectors use the old style square connectors.....
Wednesday, July 05, 2006 6:12 AM
My Ford Green Tops were awesome for me. Great idle and everything. Didn't know that about the intake valves, though. What about Red tops?
O noes!
