Whats ur injector constant w/310 cc injectors. - Tuning Forum
Wednesday, July 26, 2006 11:45 AM
Hey guys,
well, i'm going to change my injector constant bc i'm using larger injectors. 32lbs ~335cc vs the stock s/c 310cc injectors. Looking at my stock s/c setting, it shows my injector constant as 0.32359 . Just curious if this is the same as everybody elses. I'm curious b/c with 24lbs injector the constant is 0.2xxx and i thought the bigger the injectors the smaller it stays open. Anyhow..just curious to what other stock s/c constants are and if you have bigger injectors (what size are they, and what size where they before) and what itsthe constant is set to now.
Nate
1995 Cavalier W/2k1 Engine
Re: Whats ur injector constant w/310 cc injectors.
Wednesday, July 26, 2006 11:51 AM
doh..i downloaded another s/c tune from the bin file and its the same.
Saturday, July 29, 2006 11:30 AM
yea, I think the Reflash actually needed larger injectors, but GM just 'over clocked' the 310's to work
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Saturday, July 29, 2006 1:38 PM
mine ran low 13's for afr , and when i switched to 36lb and droped the fuel pressure , i picked up alot more power
