Autotune with HPT?? - Tuning Forum
Autotune with HPT??
Friday, September 15, 2006 1:24 PM
I have 2 friends running boosted applications with mega squirt, and what thet can do is Data log for 5-10minutes, and then analyze.... and it adjusts the VE tables accordingly... you think it would be possible to somehow plug our data log into that and get an autotune?? (they have wideband input too)
I wonder if someone could take our data log raw info and use that in there program to edit our VE tables... I personally don't have the abilitly but someone might... hmmm
Re: Autotune with HPT??
Friday, September 15, 2006 4:24 PM
I'm thinking about writing some software that does something similar...
Friday, September 15, 2006 7:04 PM
That would be pretty badass!
Friday, September 15, 2006 8:50 PM
hptuner logs would have to be decrypted and parsed... if someone could get the hpl file into some data format like any database or csv's then i could write a program that would spit out to you what your new ve table should be in order to get a target a/f based on the map/rpm/wideband/throttle...
this is a great idea by the way...
Friday, September 15, 2006 11:16 PM
that would sure be nice
Saturday, September 16, 2006 7:20 AM
any reason why chris or keith wouldn't help us out with this??? they might think it is a good idea too... I am sure they could help us do something so the values would be layed (laid) out on a spread sheet with 0.1 seconds increments or something
Saturday, September 16, 2006 7:47 AM
Acer wrote:hptuner logs would have to be decrypted and parsed... if someone could get the hpl file into some data format like any database or csv's then i could write a program that would spit out to you what your new ve table should be in order to get a target a/f based on the map/rpm/wideband/throttle...
There is a menu item to export the hpl file to a csv...
i'm already discussing this with Chris, he's very helpful so far.
Saturday, September 16, 2006 9:18 AM
that is so awesome man, I understand it would work on % and stuff to lower fuel and it would not be perfect after one "autotune" but that would really help dial things in.
Sunday, September 17, 2006 11:17 AM
There's an easy way to do this, without special software, watch for an FAQ later tonight on VE tuning.
Sunday, September 17, 2006 12:51 PM
the FAQ, on this site, 4cyl, or HPTuners.com ??? I will chec k all of them
Sunday, September 17, 2006 1:59 PM
Here, new post, later this evening.
Monday, September 18, 2006 6:35 PM
Shifted wrote:Here, new post, later this evening.
1995 Cavalier W/2k1 Engine
Monday, September 18, 2006 7:28 PM
