Electromotive Tec III - Tuning Forum
Friday, September 22, 2006 9:16 PM
I have a tec III installed in my 97 2.4L Cavalier, t3/t4 57 trim turbo with 750 CC injectors. Now to my questions.
1). You guys that have this system, do you use a cam sensor?
2). Anybody willing to share your bin file? Mine is base tuned but i'd like to compare others maps to mine for learning purposes.
3). Anybody know what happens if you run without a cam sensor in sequential mode? I goofed and told the tuner i had a cam sensor installed (cause the cars have them stock) and did not know it was unhooked. So now it is running sequential without a cam sensor. It seems to run just fine but i obviously get error code 13 - cam sensor failure. Trying to see what i can do cause the guy who tuned it would have to be flown here if we can't fix it without him here.
thanx
Kris Bloom
Street Challenge
http://www.streetchallenge.info
Http://www.streetsourcemag.com/projectz/ <--- The Cav
Re: Electromotive Tec III
Saturday, September 23, 2006 11:21 AM
bump
Kris Bloom
Street Challenge
Saturday, September 23, 2006 9:05 PM
It cant run in sequential mode without the sensor.
code 13 also means its now running in batch fire mode.
batch/sequential means nothing to operation. Some extremely high output engines can get pressure surges in the fuel rail when many large injectors are cycled at the same time, but its rare.
The only Tec files I had are gone because the laptop was stolen.
sig not found
Sunday, September 24, 2006 9:07 AM
protomec wrote:It cant run in sequential mode without the sensor.
so should i worry about it? cause it runs good... should i leave it alone or try to get it into phased mode?
Kris Bloom
Street Challenge
Monday, September 25, 2006 9:01 PM
wouldn't worry
pre 95, the majority of cars ran this way.
means nothing overall
sig not found
