How many frames per second HPTuners?? - Tuning Forum
Saturday, October 28, 2006 10:20 PM
I checked my data logs, and I get 4 FPS, is it possible to up that to 20, 30, 40 ++ ???
I wanna see if a sensor is screwing up at higher rpm causing my misfire.
Re: How many frames per second HPTuners??
Sunday, October 29, 2006 5:16 AM
FPS depends on how many data items you are logging. If you have the table view filled, then its going to be slower. If you want to know misfires at higher RPM's, just log the critical ones.
Sunday, October 29, 2006 2:18 PM
so just log less and it will go up... good to know, I can log certain things that I think are my issue, 1 at a time
