quick HPtuners question - Tuning Forum
Wednesday, January 10, 2007 6:55 AM
Can you do a reflash like:
2000 2.4 auto PCM to a 2000 2.4 5spd PCM?
____________________________
Dracula called, and he's coming tonight!
Re: quick HPtuners question
Wednesday, January 10, 2007 8:49 AM
Yes, I did exactly that.
Wednesday, January 10, 2007 9:48 AM
would I also be able to do a supercharger flash as well?
Wednesday, January 10, 2007 10:07 AM
Yes, I have also done that to my vehicle.
Wednesday, January 10, 2007 3:59 PM
how would you flash from an auto to a 5 speed?
'00 Grand Am 2.4L LD9
http://www.cardomain.com/ride/816505
Wednesday, January 10, 2007 5:10 PM
Get a 5 speed file, and then flash it to the ECU.
Wednesday, January 10, 2007 5:36 PM
simple enough :p
Wednesday, January 10, 2007 5:55 PM
you can NOT reflash from a NA to a "GM s/c" tune though, the operating system is done. Once you have brought it in and had the O/S changed, you can edit and play with the GM s/c tune as usual.
The NA is an Alpha-N (or close to) and the GM s/c is map v/s rpm.. which is better for boosted applications
Wednesday, January 10, 2007 6:26 PM
ge_forcez22 wrote:you can NOT reflash from a NA to a "GM s/c" tune though, the operating system is done. Once you have brought it in and had the O/S changed, you can edit and play with the GM s/c tune as usual.
Thats incorrect, I've done this on over 5 NA PCM's now for my customers.
Thursday, January 11, 2007 12:13 AM
shifted how about those with a 97 pcm any probs with it, or can it be done
Thursday, January 11, 2007 5:01 AM
You can flash it to a 5 speed, but you cannot put ANY 2k+ flash onto a 99-, S/C or NA.
Thursday, January 11, 2007 9:50 AM
thats what i thought and thats lame cuz id rather use the 2k+ but im not all up for the wiring and everything to get the 2k in there since i alreday swapped my 96 to a 97 and its rather cold out in IL
Thursday, January 18, 2007 1:46 PM
I don't want to make another thread. Does HPtuners use 2 credits for limitless licencing on a vin, or is it 4 credits?
Thursday, January 18, 2007 2:04 PM
2 for a single vin, 4 for a model year
Sunday, January 21, 2007 7:04 AM
Question in regards to this. 1 can you make a manual ECU a auto one? I assume yes. When doing this does it change how HPT reads the car? I mean I heard when you get the GM reflash it makes it a new ECU so you have to re-register the car? Is any of this true? Thanks
Sunday, January 21, 2007 7:49 AM
Yeah, you can. And it works the same way, its pretty much a new ECU to the HPT cable, so it makes you register it (in fact, it won't flash the new file without registering it first).
Sunday, January 21, 2007 9:02 AM
Shifted wrote:Yeah, you can. And it works the same way, its pretty much a new ECU to the HPT cable, so it makes you register it (in fact, it won't flash the new file without registering it first).
Ok so if you reflash a auto eCU to a manual or the other way around does it also become a new ECU to HPT?
Sunday, January 21, 2007 2:10 PM
Yeah
Sunday, January 21, 2007 2:31 PM
Ok, thanks for the info. I should be ordering my HPT in the next month.
