well i was thinking about getting projectors but i hear they suck on stock bulbs so i was wondering whats the most cost effective way to get hids.. new or used it doesnt matter as long as they work.. any suggestions. Perhaps a junk yard .. off a particular car? or links would be helpful thanx
HID-Planet  They have forums you should check out for info.  They also have a classifieds were you could probably get stuff at a good price, and then there is always ebay.  I take it you want to do a retrofit?
retrofit.. i have no idea i dont even know how to hook them up but ill have to figure it out iw as just wondering if there was an easy swap and how much it would run ect
EBAY... i got mine for $212 shipped... bright as a bitch.... and they only have 35 watt bulbs... you can always step up for brighter...
now my BMW lights use H7s... so i ordered an H7 light kit
im not sure if the third gens still use 9004s... order a kit with those bulbs... if not just order one for your low beams...
HIDs are REALLY simple to hook up...
is it possible to just order it for low beams?... how do i find a REALLY blue one and how do u hook them up
a 8000k kit should be a whitish blue, i know thw 12000k kits are purplish
Brandon Schmidt wrote:is it possible to just order it for low beams?... how do i find a REALLY blue one and how do u hook them up
Heres my entire setup
REPOSTED FROM www.v6z24.com Appearance forum By IMCensored1
Images hosted on www.j-body.tk (if ya get red xs hit refresh... my server host is doing routeine mantanance for a little while)
here are the pictures (all images located at
http://www2.j-body.tk/images/hid/)
Yes i know i look dumb as hell in these photos.... i was in a rush and taking quick photos
So anyway my BMW Projectors with Silvania Silverstars H7s were dim as hell while driving... so i ordered an HID Kit off Ebay...
I know its been a while since ive posted anything about my car... stereotypically... i got me a kick ass gurlfriend... and now found myself short on cash flow... ya noe how it goes....
So this is my set up
This is some @!#$ right here... why the instructions says to make black hot and red ground is beyond me... i hooked it up both ways, with only red hot and black ground (as it should be) working....
For all of you with E36 BMW lights... dont u wish you can pull the whole thing out this easily ... haha
Now heres how i did it... i took the light and placed it in to the light, then connecting the HID Box to the lights... then taking the factory light inputs and running those to the HID Box... its that simple...
Now can you tell what is Silver star and what is HID
I temperarly mounted the HID boxes with strip ties
Finished product
grr i need an edit button... let me try that again...
http://www.j-body.tk/images/hid/)
Finished product
I forgot that my main server now was my aux server 2 months ago... sorry for the double post...
Now this isnt a direct cross because i have a BMW set up... but it should give you an Idea...
in your last picture are you shining your lights at the garage?  they dont seem to be too bright if you are.
its a bad picture... i was standing at an angle and i didnt turn it on night mode... so the flash issue messed it up...
Wow, I'm assuming that last pic is with you hids on if so thats bad. Could it be that your camera took all the light away? Since you said that you have a bmw set up you probably already know that you can get better results. I mean just take a look at my pic with hids. I'm currently using infinity projectors retroed into my cavailer headlamps. BTW this is only with one headlamp on. The headlamp was not on my car yet so thats why its so low.
The aftermarket ones that they make for the cavailer suck and throw out light all over the place. You best bet would be to do a retrofit using oem equipment like stuff off a bmw, acura..... Doing a retro fit will give you a hell of a lot more light out compared to the ebay ones
04 Cavy LS Sport
^^^^ My Custom Projectors ^^^^
so can NE1 specify on ho to go about doing a retrofit?
wait for it... wait for it... NOW GO!!  ---> '02 LS Sport <---
Yahoo IM : buzz122          AIM : buzz122cav
Here are some retrofits, You need to register first on hidplanets site to see the retros.
SRT-4 Retrofit
Civic Retrofit
01 Cavalier
04 Cavy LS Sport
that was pure camera... the camera really distorted the picture... i didnt put it on night mode... imma take a new pic soon and upload it
so the only way to get projectors for the 95-99 would b eto get the crappy ones from ebay? Has anyone tried retrofitting any for the 95-99?
So how would something like this be?
Clicky  Would this just slap right in and be bright as a mofo?  And i was wondering about the bulbs, would 9000k be the brightest?  or just a different color?
4100K is the brightest. The Higher K you go the less brighter its gonna be. 9000K would be hella blue, maybe some purp too?
I noticed that on those kits they dont have 4100K so 4500K bright as well. I dont know much about there bulbs but there ballasts are oem equipment which are good.
04 Cavy LS Sport
Rick  <---- from what i understand from the "clicky", the first thing that you would need,is a headlight housing that has two bulbs, not a single bulb with a double filament, in order for that kit specifically to work, and be able to cal it DONE!!! If you have that, then Yes it would work...
NE1 can correct me if i'm wrong.....
