2002 cavalier hid please! - Exterior Forum
Friday, February 24, 2012 3:10 PM
Hey all. So to start off I have been reading and looking and well I cant come up with my solution so I was wondering if you guys can help, all jokes a side.
I drive a 2002 cavalier, 2.2L
I know there is an issue with hid/9007 cavalier set up.
Now I have recently installed a 8000k bi-xenon kit. With the harness.
I haven't disable my DRL's. So of course when I put my car in drive it flickers. Some reason I found that if I put the lights "on" then put the car in drive and turn the lights "off" they stay on. Now my main issue is, that when I turn my lights on all the way. The High beam indicator stays on? I go to click them off and they stay on.
I'm wondering is it cause I havent disable my drls? Or is there something more I need to look into. I appreciate any help I can get, Thank you.
Re: 2002 cavalier hid please!
Friday, February 24, 2012 4:10 PM
You need to disable your DRL's, and from the sound of it you will have to switch a couple of the wires around in the blue plug.
Friday, February 24, 2012 4:30 PM
I figured that. Ill ground that out tomorrow. I know its the dark blue wire that needs to be grounded? Now when I cut the wire. Is it the wire that comes from the wire wall I need to ground? Or is it the wire that comes out of the plug? and also the wires that are in the blue connector are yellow brown and blue.
