Altezza black euro tail lights - Exterior Forum
Thursday, May 24, 2012 8:05 AM
I got some altezzas a couple days ago and having a issue with the trunk part going on properly, for some reason the "clips" will not stay on, should i just jbweld or epoxy them on so they stay and water doesn't get in the assy. when it rains? any ideas would be appreaciated thanks ( its the center section that im having the issue with incase no one knows what im talking about)
Edited 1 time(s). Last edited Thursday, May 24, 2012 8:06 AM
Schrödinger's cat
Re: Altezza black euro tail lights
Thursday, May 24, 2012 8:54 AM
I had the same problem. The stud bolts that are supplied with most are not correct for the plastic bolts that are on the Altezza lights. I ended up re-using the stock clips as they work much better. I do have some gap on my light bar now btw but I havent had any issue with rain or water leakage. the middle should be the easiest to get attatched but the edges will always have a gap. in fact the two studs on the ends I couldnt get bolted at all. but the bar has been fine with no issues for almost 2 years now.
Because Racecar.
http://www.cardomain.com/id/tperrotte777
