front turn signals - Exterior Forum
front turn signals
Wednesday, May 23, 2012 8:55 PM
There must be away to get my front turn signals to stay on bright, when I have my park lights on, it dosent matter to me if they even flash. Dose any one know how to to it?
Re: front turn signals
Wednesday, May 23, 2012 9:43 PM
Turn Signals have 3 wires, high, low, and ground. Just switch the two. Some cars turn off the low when they flash some do not. Not sure about j bodys. You could just by switch back bulbs. They look sick.
Thursday, May 24, 2012 5:10 PM
Tryed it and made a mistake because I was in a hurry and splice the ground and power together, and now I have no blinkers, checked the fuse its fine, could it be the flasher?
Monday, June 04, 2012 10:46 PM
If you don't want them to flash, just cut the turn and park wires, leaving some slack at the socket to work with. Splice the harness side park wire to the socket side turn wire.... or just get switchbacks as suggested.
You can then relocate the turn signal elsewhere.
For the other issue, undo the splice you made and set it back to how it should... you should then have blinkers unless something in the flasher died.
