Apparantly
switchgrass can provide 5 times the energy needed to grow it. That blows corn-based ethanol out of the water.
But yields from a grass that only needs to be planted once would deliver an average of 13.1 megajoules of energy as ethanol for every megajoule of petroleum consumed—in the form of nitrogen fertilizers or diesel for tractors—growing them. "It's a prediction because right now there are no biorefineries built that handle cellulosic material" like that which switchgrass provides, Vogel notes. "We're pretty confident the ethanol yield is pretty close." This means that switchgrass ethanol delivers 540 percent of the energy used to produce it, compared with just roughly 25 percent more energy returned by corn-based ethanol according to the most optimistic studies.
Other development in alternative energy (all of these happen to be solor based) include -
Super Soaker Inventor Aims to Cut Solar Costs in HalfQuote:
Solar energy technology is enjoying its day in the sun with the advent of innovations from flexible photovoltaic (PV) materials to thermal power plants that concentrate the sun’s heat to drive turbines. But even the best system converts only about 30 percent of received solar energy into electricity—making solar more expensive than burning coal or oil. That will change if Lonnie Johnson’s invention works. The Atlanta-based independent inventor of the Super Soaker squirt gun (a true technological milestone) says he can achieve a conversion efficiency rate that tops 60 percent with a new solid-state heat engine. It represents a breakthrough new way to turn heat into power.
Johnson, a nuclear engineer who holds more than 100 patents, calls his invention the Johnson Thermoelectric Energy Conversion System, or JTEC for short. This is not PV technology, in which semiconducting silicon converts light into electricity. And unlike a Stirling engine, in which pistons are powered by the expansion and compression of a contained gas, there are no moving parts in the JTEC. It’s sort of like a fuel cell: JTEC circulates hydrogen between two membrane-electrode assemblies (MEA). Unlike a fuel cell, however, JTEC is a closed system. No external hydrogen source. No oxygen input. No wastewater output. Other than a jolt of electricity that acts like the ignition spark in an internal-combustion engine, the only input is heat.
Power from space? Pentagon likes the ideaNeat idea but will probably only be feasible for military power for a long time. And dare I say how easily this could be made into an awesome weapon?
Scientists Use Sunlight to Make Fuel From CO2Quote:
Researchers at Sandia National Laboratories in New Mexico have found a way of using sunlight to recycle carbon dioxide and produce fuels like methanol or gasoline.
The prototype will be about the size and shape of a beer keg. It will contain 14 cobalt ferrite rings, each about one foot in diameter and turning at one revolution per minute. An 88-square meter solar furnace will blast sunlight into the unit, heating the rings to about 2,600 degrees Fahrenheit. At that temperature, cobalt ferrite releases oxygen. When the rings cool to about 2,000 degrees, they're exposed to CO2.
Since the cobalt ferrite is now missing oxygen, it snatches some from the CO2, leaving behind just carbon monoxide -- a building block for making hydrocarbons -- that can then be used to make methanol or gasoline. And with the cobalt ferrite restored to its original state, the device is ready for another cycle.
Fuels like methanol and gasoline are combinations of hydrogen and carbon that are relatively easy to synthesize, Stechel said. Methanol is the easiest, and that's where they will start, but gasoline could also be made.
The Sandia team originally developed the CR5 to generate hydrogen for use in fuel cells. If the device's rings are exposed to steam instead of carbon dioxide, they generate hydrogen. But the scientists switched to carbon monoxide, so the fuels they produce would be compatible with existing infrastructure.
Eric Esler wrote:Why does no one mention tobacco for ethanol? Research is showing it has great potential, and it can grow in large quantities almost anywhere.
Link please - that'd be great.
I've never heard of this "part throttle" before. Does it just bolt on?
Power from space? Pentagon likes the idea Neat idea but will probably only be feasible for military power for a long time. And dare I say how easily this could be made into an awesome weapon?
When reading this article, it seems like the only objection is the expense of getting the stuff out to space. However, if you were to use the space elevator:
Space Elevator
I have been using ethanol for some time now as have many Iowans. I would bet that there is some money trading hands. I bet the outcome of this study as is the case with most is influenced by money. Think about what powerful wealthy special intrest group would like to see us not use 10% ethanol or say it this way 10% less petroleum.
All pump gas has been 10% ethanol in Minnesota for years.
We have ethanol plants where I live.... when the wind shifts... they can make a small town sell like a brewery.... because well.... that's what ethanol plants are.... but it doesn't make anyone sick...
Ethanol is actually corn alcohol.... that's it.... anyone ever seen a bottle of everclrear? they just call it ethanol because it's used as fuel.
You can drink ethanol in it's pure form but it's hard since its 200 proof..... you can't drink gasoline..... so why would the fumes from burning something you can drink make people sicker than something that's 100% poison like gas or oil.... it doesn't make sense...
I'm willing to bet that the oil companies either funded their research or at least had something to do with it.
