camshaft replacement - Second Generation Forum
Friday, January 11, 2019 1:45 PM
My bird has been in the garage since Nov 26, 2018. Went in for a blown head gasket and the shop discovered that the camshaft was scored badly. Apparently finding a replacement cam was to be more difficult than he had thought. I've been scouring the web for over two weeks now in an attempt to locate one myself, The bird is a 1988 Sunbird Gt Turbo coupe convertible. The engine code is M. I have found several camshafts out there for the engine code K naturally aspirated. the code M is a different story. Should anyone here have a idea where I might find the correct camshaft it would be greatly appreciated. This bird needs to fly once again.
Re: camshaft replacement
Friday, January 11, 2019 2:32 PM
Any 92 - 94 LE4 cam (2.0 OHC) is the same as the earlier Turbo cam.
I don't have the lift specs, I'll try to find them.
Many aftermarket cams can be found in Europe.
Don't forget the ballbearing that goes inside the cam when replacing it.
Doug in P.R.
92 Pontiac Sunbird LE, 2.0, AT, Red / Black with Grey 148K miles. Hurricane Maria Surviver! ( It takes a licking and keeps on ticking ! ).....in Salinas, Puerto Rico!
Friday, January 11, 2019 2:52 PM
87-91 non turbo cam has a 179*/192* duration
92-94 non turbo and 87-91 turbo 189*/189* duration
Wolverine part # CS866 or
Melling part # SPC-19
Doug in P.R.
Friday, January 11, 2019 3:04 PM
I guess those 2 above are hard to find so here is another:
Sealed Power CS 838 ( available from Jegs.com )
I found that the proper duration is 214*/214* for this cam not 189*/189*.
Doug in P.R.
Saturday, January 12, 2019 3:21 AM
A quick search found none available new, looks like Europe is the only answer.
Old post with links :
https://pontiacforum.com/pontiac/showthread.php?t=36000
Doug in P.R.
Thursday, January 17, 2019 3:11 PM
which year Sunbird camshafts are interchangeable with my 1988 Turbo GT. 2.0
Friday, January 18, 2019 9:58 AM
92-94 2.0 OHC non turbo.
87-91 2.0 OHC turbo.
Doug in P.R.,
Sunday, January 20, 2019 2:25 AM
I will start a new search for the 92-94 camshaft. I'm still looking for the specs. Does 189-189 duration sound familiar to you?
Sunday, January 20, 2019 8:00 AM
I mentioned above it's 214/214 not 189/189.
Doug in P.R.:-)
Thursday, January 31, 2019 9:37 AM
https://row52.com/Vehicle/Index/1G2JB34M8L7570213
Turbo Parts car in Colorado.
Doug in P.R.
