i tried unbolting my front bucket seats and sliding them in the rear seat spot.  Will the seats fit if i take of f the mounting brackets on the bottom of them or what can i do to make them fit with out having your head bent for ward???
ive seen it before...but i havent seen anyone siting in them. good luck.
 -Www.IznTrbl.Com-
 -Www.IznTrbl.Com-
you'll have to take off the sliders in order to mount the bucket seats in back.  there's just no room for them.
If I ever get to ride in your car, I call Shotgun right now!
Someone gon' die!
Mighty Jabba will not ride in rear bucket seats.
Jabba Hutt wrote:Someone gon' die!
Ignorant & uninformed comment...
If installed carefully and correctly, rear buckets can be just as safe as the front buckets. Without having to worry about an airbag smacking into your face.
You definitely need to take off the stock sliders. Mounting them can be done by creating custom brackets and either welding them or using bolts to connect said brackets to the floor.
Interior FAQ -
J-Body of Michigan -
it's not even the seats that hold you in place in the case of an accident.  it's the seatbelts.  as long as the brackets are made well enough, there shouldn't be a problem with rear bucket seats.
i dont care what it takes im gonna fab something up!!!!
Interior FAQ -
What the hell? Apparently I already posted that. An hour and fifteen minutes ago.
Stupid time machine being broken...
Interior FAQ -
You might have to cut out some of your floor and weld in some new sheet metal to do it.  Then you could use the same mounting brackets and sliders.  It's worth the work and effort.  I've though about doing this myself.
Sam
Raptor,
I was totally kidding.  No need to call me ignorant.
Jeez, dude, calm down a little.
Sam Krajnik wrote:You might have to cut out some of your floor and weld in some new sheet metal to do it.  Then you could use the same mounting brackets and sliders.  It's worth the work and effort.  I've though about doing this myself.
This would also require either reshaping the gas tank (yuck), or getting a fuel cell (yay).
Jabba: I was perfectly relaxed. It's sometimes hard to sense sarcasm or humorous comments on a static medium like a forum. No hard feelings.
Interior FAQ -
Raptor, I agree - no problemo.
97zburner,
Looks like there is a lot of work ahead to put buckets in the back - cool if you have tons of cash and time.  Me, I would probably spend both on other projects.
But I'd like to see pics if you end up doing it.
Jabba: werd.
Pretty basic install... I got a good deal on the seats, and the necessary hardware cost me about $50. Total project was in the range of $85. Took me about a day to complete.
Interior FAQ -
raptor did you cut anything out???  or just made custom brackets?
I know i read somewhere, that you need to drop down the gas tank to bolt the back buckets into place. Because you can't get to the bolt from above.  Is that correct?
Portage, MI
97zburner: I didn't cut anything in the car. I did make custom brackets, using some nuts, bolts, and 16g L-shaped bars of steel.
ruen: Yeah, you have to drop the gas tank to drill holes for the bolts. Otherwise, you'd drill right into the gas tank. The gas tank should be removed if you're welding brackets in, also.
Interior FAQ -
word Jermaine is smizart!
Portage, MI
i think its easyer to do in the sedans due to the higher roof in the back. i was thinking about doing this in my 05 coupe awhile back but i didn't want to drop the gas tank and drill through the floor.
its been done like others have said, but its probally a lot of work/fab. but if your up for it it will  worth it in the end.
good luck
hope it goes smoothly for you.
http://registry.gmenthusiast.com/images/my2005cav/my%20car%20the%20bash.jpg
