99 PCM SWAP - Tuning Forum
99 PCM SWAP
Sunday, October 02, 2005 10:42 AM
i cant seem to find this info anywhere.... so to remedy the EGR ses light from the HO mani, i hear you can put in a computer from a 99+ 2.4. what all is required in that, do you just plug it in and go?
Re: 99 PCM SWAP
Sunday, October 02, 2005 12:10 PM
As far as I know, just plug in the new PCM and the light should go bye bye.
Re: 99 PCM SWAP
Sunday, October 02, 2005 12:19 PM
that would be sweet. is there anyone out there that has actually done it that can verify this?
Re: 99 PCM SWAP
Tuesday, March 21, 2006 3:34 PM
I'm interested in this too. I have the damn egr simulator and it just sucks.
Re: 99 PCM SWAP
Tuesday, March 21, 2006 3:37 PM
i believe there is more work involved but if i'm wrong thats cool because i have the engin wiring harness and pcm sitting infront of me
Re: 99 PCM SWAP
Tuesday, March 21, 2006 9:40 PM
Probably have to do the fuel password relearn... http://www.j-body.org/faq//98/
Re: 99 PCM SWAP
Wednesday, March 22, 2006 5:04 PM
What is the deal with the knock sensor for this swap?
Re: 99 PCM SWAP
Wednesday, March 22, 2006 5:09 PM
you have to drill it out because its a differant size than the 96-98
Re: 99 PCM SWAP
Thursday, March 23, 2006 6:07 PM
need mmore input aka bump
Re: 99 PCM SWAP
Thursday, March 23, 2006 6:33 PM
I know that a few guys have done this. Can ayone please write a step by step on this?
Re: 99 PCM SWAP
Friday, March 24, 2006 5:58 PM
Back to the top.
Re: 99 PCM SWAP
Saturday, March 25, 2006 1:46 AM
How to install the 99 PCM
1. Put in 99 PCM (or reflash yours to 99 vin).
2. Locate the EGR wire in connector one (C1-66 Black), and the Knock sensor in connector one (C1-33 Drk Blue) and remove the pins from the connectors (pull the backs off, and the blue clear inside, push pins out)
3. Locate the new locations for the new wires (C1-32 and C1-34)
4. Put the Drk Blue wire in C1-34, and the Black in C1-32.
5. Put the plugs back together, and install the PCM.
6. Locate both the Knock sensor plug, and EGR plug. Pull the Black wire out of the EGR harness. Either run it to the Knock sensor location (pull back wire loom) or add wire to it.
7. Cut the connector off the stock Knock sensor, and wire that to the Orange wire on the new Knock sensor. Wire the Black wire to the White wire on the Knock sensor.
8. Install knock sensor.
Done.
97 diagram
99 diagram
I *might* be wrong on the knock sensor plug itself, as in which wire goes to which, but I'm 90% sure I'm right
Hows that for a write up?
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
RACER X - '78 Opel Kadett W41 Swap
Re: 99 PCM SWAP
Saturday, March 25, 2006 1:47 AM
***Edit***
With the HP tuners software, you can actually remove the fault codes, so they dont set lights...... so no need to wire in the new PCM (unless doing it for the High Impedance injector driver)
Re: 99 PCM SWAP
Saturday, March 25, 2006 12:42 PM
yeah but when is this hp tuners software be available. it keeps getting pushed back
Re: 99 PCM SWAP
Saturday, March 25, 2006 5:46 PM
You can order it right now, I ordered mine this last monday.
Re: 99 PCM SWAP
Saturday, March 25, 2006 7:44 PM
Thanks for the write up. How much is that software going for?
Re: 99 PCM SWAP
Saturday, March 25, 2006 8:00 PM
$500 for the basic
$650 for the advanced
check the thread for more info
Re: 99 PCM SWAP
Wednesday, March 29, 2006 6:52 PM
Does anyone have the part # for the 99 pcm for a 5 spd?
Re: 99 PCM SWAP
Thursday, March 30, 2006 1:41 AM
there really isnt a part number...... pretty much all J's use the same computer, its just the programming inside that is different. I usually use a VIN number for a vehicle of the year I want (IE 99 5 speed) and flash the PCM to that VIN. GM stores all the VCI numbers by VIN on their network, so you end up with the last update to that VIN.
Re: 99 PCM SWAP
Thursday, March 30, 2006 10:27 AM
Brian is right, spotbee is wrong.
I've done it, and yes you'll need a '99+ knock sensor (2 wire) to replace your current (1 wire). Nice part is they use different / dead pins on their respective ECU so no issues. When running the pre-99 ECU it will read from the 1 wire and ignore the 2 wire, and vise versa for the 99' version.
HO manifold, no CEL.
Good luck,
Matt S.
Re: 99 PCM SWAP
Friday, March 31, 2006 5:23 PM
Is it safe to say that a 99 to 01 pcm are the same? Thanks for clarifying these questions guys.
Re: 99 PCM SWAP
Friday, March 31, 2006 6:23 PM
nope..... 99 still uses most of the 97-99 programing...... the 00+ use a bcm and doesnt do everything the 99- did.
Re: 99 PCM SWAP
Friday, March 31, 2006 8:29 PM
Thanks.
