My right turn signal is blinking fast and I have done all the usual, found a recall on NHTS (National Highway Transportation Safety Board) that they have already fixed on this car, and they will not repair it again. I am the second owner Pontiac repaired it under the first owner. Does this sound reasonable where it is a safety related item that they clearly did not fix the first time?
you have already checked all the right side turn signal bulbs to see if they are all working?
if the rear goes out, it will make the front blink fast.
that's about all the info ive got for ya. lol
good luck buddy!!!
 -Www.IznTrbl.Com-
 -Www.IznTrbl.Com-
get new bulbs and put in some bulb grease on all terminals when u install em, it works for a good while
Kill list:03 eclipse, 06 GTO, 04 Mach 1 Mustang
I tried the grease after filing down the connection but used the old bulb.  i will try it again with a new bulb thanks.
Sounds to me a light bulb problem, Or wiring connection.
