Can someone please tell me how to get in and change the bulb that lights up the shifter indicator ?  The bezel moves around but I cant figure out if it just pops out or what  and I dont want to break it...thanks
Found my own answer
Document ID# 739277
2001 Pontiac Sunfire
Console Replacement - Front Floor
Removal Procedure
On vehicles with manual transmission, release the snaps on the shift boot.
Using a small flat-bladed tool, remove the front screw cover [Note from SS:
this is a round plastic cover].
Using a small flat-bladed tool, remove the center storage pocket, if
equipped.
Remove the power window switch plate, if equipped. Refer to Power Window
Switch Replacement in Doors.
Raise the armrest (1) from the front floor console.
Remove the bolts (6) from the front floor console.
Remove the front floor console by lifting up and back. Guide the shift boot
over the optional shift knob and over the emergency brake handle.
Installation Procedure
Install the front floor console by guiding the shift boot over the optional
Notice
Use the correct fastener in the correct location. Replacement fasteners must
be the correct part number for that application. Fasteners requiring
replacement or fasteners requiring the use of thread locking compound or
sealant are identified in the service procedure. Do not use paints,
lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces
unless specified. These coatings affect fastener torque and joint clamping
force and may damage the fastener. Use the correct tightening sequence and
specifications when installing fasteners in order to avoid damage to parts
and systems.
Install the bolts (6) to the front floor console. Tighten
Tighten the bolts to 6 N·m (53 lb in).
Lower the armrest (1).
Install the optional center storage pocket. Press into place until fully
seated.
Install the optional power window switch plate. Refer to Power Window Switch
Install the front screw cover. Press into place until fully seated.
On vehicles with manual transmission, attach the snaps on the shift boot.
