Something strange happened with my z24 today. It was running fine for 20 minutes  then i ran into traffic on the highway. as soon as i get of the highway the low coolant light comes on. Then as i try to accelerate the car sputters as if its misfiring. Then all of a sudden the check engine light comes on. I pull over and for 30 mins and then check the coolant level, its full. So i start the car and drive off, the cel is off now and the car runs fine but the coolant light is still on. then the car starts to sputter again and the cel light is back on. I also realize at this point that the fan is on constantly. The cel and low coolant light are both on even though the coolant is full. Has anyone else had this problem? Low coolant level wouldnt trigger an cel?
when it comes to boobs i need a girl with bad grades cause im tired of all the ones walking around with straight a's
My low coolant light has come on before for no reason too, but it never made the CEL turn on and the car ran fine. There's almost gotta be a sensor somewhere that reads the coolant level/pressure, but I don't have a clue where it is. If you can find it, that would be the first thing I would check. When my car did that, it baffeld the crap out of me too. Mine quit on its own though, maybee yours will too if your lucky.
I hooked the car up to an obd reader and it gave me the codes po122 and po106 from previous experiences i am guessing those are throttle codes. I've checked all the sensor and hoses for the throttle body, and everything seems good. anybody else's car throw out these codes? Any suggestions on how to fix the problem?
