Important points:
-Engine stopped while driving last night.
-Pulling the fuel pump fuse and putting it back in seemed to fix it.
-Engine stopped while driving again tonight
-Would not start up this time.
-Engine was able to crank, for a long time, but didn't fire up.
Details:
So the other day I was running on fumes.  I gassed up and drove a bit, when I noticed that my ride was feeling very smooth.  Turns out the engine had shut off.  I had the Check Engine light, Check battery light and check oil light.  Power steering and brake booster were off.  So I pulled over and tried to start up the car.  The starter turned forever, but the engine would not stop.  So I checked the engine, but it was dark and I didn't really know what I was looking for.  I checked the battery terminals, checked the IDI cover connection, snugged up the relays.  I went into the car and pulled out the fuel pump fuse, put it back in a miraculously the car started.  I thought I was a genius.
Tonight it happened again.  But this time it would NOT start.  I could crank it over as long as I wanted, but it wouldn't start.
So I got it towed and went back to work.  When I got home I tried starting it up and it went just fine.
I'm going to get the computer scanned, although I don't have a CEL.
Any suggestions?
Doing a scan will not work, especially if the ce lite is not on, only thing your going to get is "no codes stored" or "passed", i would bet you 10 to 1 that the fuel pump is going out and you need a new one.
