hey guys wondering if you can help here??? this past fri. i curbed my front passenger wheel. and ever since that my abs light has been coming on and staying on till i turn the car off lately. and if i break hard or spin the wheels it ussually kicks it on plus i have this horrible clunking noise when i stop almost like the rear passenger brakes like locks to the drum and then frees up...
any help would be great, chris....
Ive curbed plenty of times, and Ive had this happened, so heres what i know from first hand experience...
When you curb your car, and the ABS light comes on, you hit it hard enough to make your brakes mad.
If you shut your car off, and turn it back on, the ABS should reset and the light go away (after a few seconds, like it normally does).
If it does not shut off (as in your case) they need to be serviced. Noit sure how or what, but they need fixin.
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.gif">
<A HREF="http://www.sandstorm-j.741.com" TARGET="_blank">Pictures and More</A>
<A HREF="http://www.crush007.com/love.cgi?id=1112583099dpm" TARGET="_blank">Love And Sex Life Prediction</A>
something like that you need to take it to your frendly neighbor hood CHevy dealership
DID SOMEONE USE THE WORDS "FRIENDLY" AND DEALERSHIP IN THE SAME SENTENCE, i really need glasses, that couldn't have been said.... they wanted 200 bucks just to tell me the codes that tripped my abs light.. and seeing how the scan tools for it are over a grand,,, lol i still have a perty ABS light, and as of a month ago.. a P/B light... so by ywars end, i'll be using flintstone breaking no doubt..... (and yes the fluid is toped off) matter facted, was even flushed when i hit 100k miles
Hi Chris
if you hit the curb you may have shaken up the Speed Sensor on the wheel.
Here's a link that is interesting and shows that the speed sensor is the most liable to damage if you curb it
http://auto.howstuffworks.com/anti-lock-brake.htm
Hope it helps
Alont
Just rop out ur abs unit... then you cant ahve problems with it, and you dont have abs. its a win-win situation
I <3 mods
thnx guys and like i said it comes and goes like when i shut off the engine and start it again it ussually turns off but when i brake hard but not hard enough for it to engage it trips the light again or when i accidentally drop the clutch and spin alittle
hit a deer tonight guys on the same side that i curbed my rim.... and now like my wheels are way un-aligned and the abs light wont go off at all.....
now thats just @!#$y luck!
... or did the deer hit you?
~The Confused One~
if it is not fixed, maybe you need them to check the codes. maybe something is throwing it off. Or ... have them reset the codes. I dont know the extent of the damage when you hit a deer, but if it wasnt enough damage worth making a claim,, then I recomend what I said above
dan
Representing the 810's ... biatch!!
[19:33] Lurch: I am sick of sex! (and you thought it would never happen)
