This could either be simple, or complex.  Complex because i spliced the wires around so i could get the yellow turn signals in place of my reverse lights.
Anywho, the problem at hand is, everything works fine when headlights are off.  When headlights are on, it triggers the tail lights which work fine, but as soon as I hit the breaks, the whole left side goes out.  Now I can't remember if they were dual ellement or not back there.  I just hope it doesn't have anything to do with the wiring for that conversion, cause I hate backtracking wiring.  Future thanks for any help and advice.
They are dual filament.  One filament for parking lights and when you hit the breaks, the parking one turns off and the brake filament lights up.  The first thing I would do is get a new bulb for the left side or check it at least.  Somethimes the simplest solution is the right one.
Jay
One huge aluminum wing - $200
More vinyl graphics than your ride can handle - $150
Decals for products you don’t even have - $10
500lbs of Car Audio equipment in the trunk - $1500
Getting slaughtered by a KIA - Priceless
