I believe my oil pump is going on my cavalier because my oil pressure keeps going to 0 when Im at idle after the car gets up to temp.  It has gotten worse and worse and now it does it when I let off the gas below like 30 mph so I am going to replace it tomorrow as it sure seems like that is it.  Please give me your thoughts because I dont want to replace it and have it not be the oil pump.  Thanks
RIP 3-23-05
I have the same Cavy and have the same problem. I swapped out the oil pump but still have low oil pressure on idle when the engine is warm.
After speaking with a couple of mechanics and getting a response to a post on this (thanks Gilles!), we determined it's worn rod bearings, a worn main bearing, or both. I don't hear a big tick when the engine runs, so the bearings aren't totally shot. I know the engine's days are numbered.
In the meantime, I'm using 40W oil and that helps to keep the oil pressure up some.
Well I went to the parts store today and had to order one and had to pay for it today.  I really hope that it is the problem with mine so I dont waste all the time changing it out as Ive never done it before.  The motor only has 84k on it so it seems a ltitle too early for it to go it runs really well and it doesnt tick or anything either like you say yours doesnt.  I sure hope this motor will last me until I can get another car as its just a temporary car until I get something else which will probably be over the winter.
RIP 3-23-05
