Message title pretty much says it all.  The previous owner of my car pulled the DRL relay, and also pulled the driver side bright, and fog lights esentially.  I've got a new relay, but I don't know where it goes.  Any help is greatly appreciated.
When you open the drivers side door look to the left of the gauge cluster on the side. You should see a thing that says FUSES. Open that up by pulling out on the little handle. It is the only relay in there. There is also a little map as to what fuse is what and it will say DRL Relay also.
http://members.cardomain.com/scrawnyguy18
Thanks, my Cavy had the map taken off of the fuse panel, as well as from the top of the relay panel in the engine bay.  I'm seriously not this much of a dumbass usually.  Thanks again though!
