has anyone ever replaced this? i need to replace my left one and was wondering if anyone knows the difficulty of tdoing this?
SPONSORED BY: CAVALIER EXTREME
front is pretty easy , rears are harder , but still on the easy scale
could u tell me whats needed to do it and where its located
Ya gotta remove the wheel- and look behind the rotor..Its the only thing back there with an electrical connector on it-- Its held in place with a small bolt- maybe 7-8mm?
Unplug the connector-- remove the bolt-- the speed sensor is also held in place with a plastic nubby thats inserted into the hub assembly.
You can probably just pry the speed sensor out- but sometimes the little nubby breaks off inside the assembly...
if thats the case, you would have to remove the rotor to push it out from the front.
<img src=http://registry.gmenthusiast.com/images/reddevil/Devil.jpg>
okay sounds great...thanks a bunch! nice detailed description
yea its right there behind the rotate, its the only sensor, you cant miss it
