so i changed my mounts and it's still shaking.. but i know it's not the mounts, so what else could it be?
define "shaking" violently shaking, or just rumbling.
Can you see it physically shaking, or does it just feel like it?
-Chris
Andrey B wrote:so i changed my mounts and it's still shaking.. but i know it's not the mounts, so what else could it be?
Which mounts did you change? Did you go back to stock mounts or aftermarket mounts?
http://members.rankmyride.com/djtorello
yes i can see it shaking.. and it's pretty annoying because i installed urethane mounts (upper and lower) so now at idle the whole interior is viabrating like a rank 7 earth quake.
Are you seeing the motor shake or stuff in the interior, because It is supposed to shake inside the cabin. That is the point with urethne mounts, it takes the vibration and movement out of the motor and transfers it into the cabin of the car.
