Hey I have searched the site and I have not been able to f ind any working links to how to replace a blown blower motor resistor. Any help would be greatly appreciated. Thanks
david pethe wrote:http://www.j-body.org/forums/read.php?f=11&i=60323&t=60323
take a look around...
Heh, yeah... The ''Help! Low Blower speeds don't work!'' post which is second from the top....
Sorry, couldn't resist
Jesse, I recently replaced mine (96' Sunfire) and didn't have to remove the blower motor, however, it did require a 1/4" drive universal socket (if I remember correctly it was 7mm, purchased from Snap-on). 1st disconnect battery ground as suggested, then disconnect resistor connector ( I needed a right angled pick for this because I am old and feeble). Remove 2 fasteners, one will need the universal (this required cutting the flooring/insulation for clearance). Reverse procedure for install. Good luck.
